Digital Voltmeters: How do They Work?
  • Thread starter Thread starter kusiobache
    Digital
The discussion centers around the functioning of digital voltmeters (DVMs), specifically how they measure voltage when connected to a battery. Participants explore concepts related to terminal voltage versus electromotive force (emf), the role of internal resistors, and the mechanisms by which DVMs operate, including the use of amplifiers and resistive dividers.
  • One participant questions how a DVM measures voltage, suggesting it might produce or measure a current and inferring that the voltage drop relates to the battery voltage.
  • Another participant explains that DVMs utilize high-input-impedance voltage followers/amplifiers, comparing them to CMOS op-amps, and suggests looking up additional information on Wikipedia.
  • A participant expresses uncertainty about how the components of a DVM work together to determine voltage, pondering whether the amplifiers act as comparators or if they use Ohm's law.
  • One participant describes the internal workings of a DVM, detailing how precision resistors and an amplifier interact to produce a readable output based on the input voltage.
  • Another participant reiterates the explanation of the DVM's internal structure and emphasizes the role of a resistor divider in adjusting the input voltage for accurate display readings.
  • A participant notes that most voltmeters have a resistance-per-volt rating or an input resistance rating, contrasting older types with modern meters that typically have a fixed resistance.
Participants do not reach a consensus on the exact mechanisms of how DVMs measure voltage, and multiple viewpoints regarding the internal workings and theories about their operation remain present throughout the discussion.
There are references to specific components and configurations of DVMs, but the discussion does not resolve the uncertainties regarding how these components interact to yield voltage measurements. The explanations provided rely on assumptions about the reader's familiarity with electronic components.
kusiobache
How do digital volt meters work?
If I connect a Digital voltmeter to a battery, how does it measure the voltage. And I'm assuming it measures terminal voltage, not emf?
This question's probably simple but it's been bugging me for awhile. All I can think of is that the DVM produces (or measures maybe?) a current, and then because of the internal resistor it measures the drop in voltage? (which would explain why the DVM has to be in parallel). Then the drop in voltage somehow = the voltage of the battery? (that's that part that would make the least sense to me, if the rest of my theory is right).
But I'm probably way off, so can someone explain it to me?
For measuring voltage, DVMs use high-input-impedance voltage followers/amplifiers. These will basically have an input structure similar to CMOS Opamps. Are you familiar with those? If not, wikipedia.org is a reasonable starting point.
I'll Wikipedia what you said and see where it gets me. Otherwise, just looking up digital voltmeters on Wikipedia (which I did a few times before) is pointless.
EDIT: So the amplifiers have a high input resistance and low output resistance, and since they are similar to CMOS Opamps they can amplify voltage. That's what I gathered/ already knew
Well then, does the DVM use the resistance and ohms law to calculate the voltage or something? Or maybe the followers/amplifiers act as comparators somehow? Or is it something else.
I kindof already know what the parts in a DVM DO, I just don't quite know HOW they work together to determine a voltage. (unless it's like a comparator or something...).
A digital voltmeter reads the voltage at its terminals. Whether this is the output of a power source or just the voltage drop across a resistor, doesn't matter.
Internally, they are like this:
http://dl.dropbox.com/u/4222062/digital%20voltmeter.PNG
Those skinny rectangles at the left are precision resistors. The input is at the left of this drawing.
Without the switch, the amplifier will produce enough output to give a reading of, say, 1999 on the display, with 199.9 mV input.
So, if the switch is set to the top of the top resistor, 199.9 mV input will produce a display of 199.9 on the display. The decimal point is added to make the display easy to read.
If the input is 60.5 mV, the display will be 60.5.
Now, the resistor divider is arranged so that on the next step down, 1.999 volts input to the terminals will produce 199.9 mV at the switch position. The amplifier works as before, but the decimal point on the display is moved to give a proper display. So, the display now shows 1.265 for 1.265 volts input.
Moving the switch further down, reduces the input voltage accurately to 1/100 th or 1/1000 th of the actual input value. Each time the amplifier gets a voltage input between zero and 199.9 mV, but the decimal point is moved to reflect the switch position.
The resistance of the resistors in the resistor string adds up to 1 megohm or 10 megohms depending on the meter. In most circuits, the small current drawn by this very high resistance has little effect on the circuit operation.
Now, the resistor divider is arranged so that on the next step down, 1.999 volts input to the terminals will produce 1.999 mV at the switch position. The amplifier works as before, but the decimal point on the display is moved to give a proper display. So, the display now shows 1.265 for 1.265 volts input.
Thank You! I was looking for a way to +rep you or something, but I don't see one. And also, thank you for the diagram!
Extra - Most voltmeters have either a resistance-per-volt rating or an input resistance rating.
The input resistance of old fashioned types was determined by the scale you were on and the resistance-per-volt rating of the meter.
i.e. if you had a 10K-per-volt meter and you were on the 5 volt scale, the input resistance was 50K-ohm.
Modern meters usually have a fixed resistance that does not change with scale - typically 10 Megohm.
- Mike
  • · Replies 33 ·
  • · Replies 26 ·
