Dimension of column- and rowspace
  • Thread starter Thread starter Niles
    Column Dimension
Niles
[SOLVED] Dimension of column- and rowspace
My book doesn't answer this question clearly, but I have notived the following connection:
Does the dimension of the rowspace of a matrix equal the dimension of the columnspace of a matrix which equals the rank of the matrix?
If the matrix has real elements, the row and column spaces have the same dimension. Furthermore, the rank of A equals the dimension of the row space of A.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
