Is the Angle Between Vector A and Ax Less Than 90 Degrees When Alpha Exceeds 90?
When alpha exceeds 90 degrees, the angle between vector A and its projection Ax is exactly 90 degrees, as indicated in figure 2-26 (a). The discussion clarifies that the angle being referenced is between the line from Ax to A, not from the origin to A. If the force leans towards the negative x-axis, it confirms that the angle between the force and the positive x-axis is indeed greater than 90 degrees. The geometry of the situation creates a right triangle, reinforcing that the angle from Ax to A remains 90 degrees. Overall, the visualization of the vectors in the specified plane supports this conclusion.
werson tan
if the alpha is larger than 90 degree ( which means the resultant F is lean towards -x axis , then the angle between the Ax and the line from Ax to A will be less than 90 , am i right ?
No. It will be exactly 90##^\circ##
(the 90##^\circ## as indicated in figure 2-26 (a) )
why , i can't visualize it??
If the force is lean towards negative x-axis , it means the angle between the force and positive x -axis is more than 90 degree, right ? then how is it possible for it to remain 90 degree?
You were talking about the line from Ax to A, not about the line from the origin to A (i.e. ##\vec A## itself).
ya , i mean the line from Ax to A, not about the line from the origin to A (i.e. A⃗ itself).
if the force is lean towards the negative x-axis then the , we would have three line , right , namely the line joining origin to Ax , A(which is lean towards negative x-axis ) , and a line which join A to negative x-axis , right ? if it is so , then the i an undersatnd why the angle is 90 degree. if it so , the triangle formed is at opposite of the current one .
I think you've got it all right and correct, just that the wording in post #1 was rather unfortunate.
With nowadays visualization possibilities it's almost a stone-age approach to put things in words, but let's do it anyway:
let's look in the blue plane of figure 2-26 (a) for the case ##\alpha \in [\pi/2, \pi]## where all the angles in our story are
[edit] I mean to say that all the angles are in that plane. Sorry for the ambiguity.​
so the vertical line Ayz is in the yz plane and that plane is perpendicular to the x axis.
and as you can see the line from Ax to A (the green line) is parallel to that plane and therefore also perpendicular to the x axis. Hence my 90 ##^\circ##.
You of course in your post #1 meant to refer to the angle between ##\vec A## and ##\vec A_x## which as you can see is ##\pi-\alpha ## and thereby in the range 0 to 90##^\circ##.
Note that I forgot to draw the arrow above ##\vec A_x## and ##\vec A_{yz}##. Nobody is perfect, be we keep trying.
To be specific: in ##\vec A_x = A_x\, \hat\imath\ ##, ##\ A_x## is a number (negative for the alpha in the picture: ##A_x = |\vec A | \cos\alpha##​
Likes werson tan
