Direction of field intensity .?
The discussion centers on the confusion regarding the term "electric field intensity" in relation to determining the direction of the electric field at a specific point on an equipotential line. Participants clarify that "electric field intensity" typically refers to the magnitude of the electric field, which is a scalar quantity and does not have direction. The focus should instead be on identifying the vector that represents the direction of the electric field at point x. The correct choice will be the vector that is perpendicular to the equipotential line, as electric fields point from high to low potential. Overall, the terminology used in the question is misleading and should be clarified.
Direction of field intensity...?
Problem:
"The vector that best describes the direction of the electric field intensity at point x on the 200Volt equipotential line is"?... ...(five multiple choice options)
There is a diagram of decreasing/increasing equipotentail lines with a point "x" on one which from four vectors are going, two parallel to the line and two perpendicular.
I know the answer they want, so I think I know what they mean( what direction is the electric field vector in).
My question is with the wording, "direction of the electric field intensity".
Does this even make any sense?
From what I understand "electric field intensity" is the magnitude of the electric field at that point. So it is just a scaler and does not have a direction...
Or am I missing/misunderstanding something?
Now playing: Nine Inch Nails - Head Like A Hole (Soil)
The term "electric field intensity" does not make sense in this context. The vector that best describes the direction of the electric field at point x is the one that you need to select from the multiple choice options.
