Miike012 said:how do I determine the direction of the force?
To determine the direction of force, you can use Newton's Second Law, which states that force is equal to mass times acceleration. By knowing the mass and acceleration of an object, you can calculate the direction of the net force acting on it.
Net force is the overall force acting on an object, which is the sum of all individual forces. Individual forces are the separate forces acting on an object, which can be balanced or unbalanced and have different directions.
Yes, forces can act in multiple directions on an object. When this happens, the forces are added together to determine the net force and direction of motion.
To determine the direction of force on an inclined plane, you can use trigonometry. The force acting perpendicular to the plane is equal to the weight of the object, while the force parallel to the plane is equal to the weight multiplied by the sine of the angle of inclination.
According to Newton's Second Law, the net force acting on an object determines its acceleration, which in turn affects its motion. A greater net force will result in a greater acceleration and therefore a greater change in motion.
