Direction of induced current question
In the discussion about induced current in a conductor placed between a north and south magnet, the scenario involves a metal pole oriented perpendicular to the magnetic field. The upward force on the conductor leads to the question of the direction of the induced current. The left-hand rule suggests that the current flows from the top (X) to the bottom (Y) of the pole. However, there is a conflict regarding the induced current's direction, as the upward force would imply that the induced current should create a magnetic field opposing this change, potentially indicating a downward force. Clarification on the application of the right-hand rule for induced electromotive force (emf) is also mentioned.
Learnphysics
There is a conductor; a metal pole say, in between a north and south magnets. North on the left, south on the right.
The conductor is layed out in such a way that it is perpendicular to the magnetic field lines going from north to south. Let's label the metal poles X for the TOP of the pole Y for the bottom.
There was a force exerted on the conductor in the UP direction, lifting it.
A current was induced due to this force, which way was the current flowing?
From the "left hand rule" (basically if magnetic field is in one direction, the force is perpendicular to it, and the conventional current is flowing perpendicular to them both, its a pretty common rule)
Im lead to believe that the current will be flowing from X to Y.
HOWEVER a conflicting idea caught me. If the FORCE exerted to LIFT the object was in the upward direction, wouldn't that mean that the induced current would create a magnetic field to OPPOSE this change? Thus wouldn't the force actually be DOWNWARDS?
Here's a picture:
Not sure if itl'l work, thus i included a description above
Left hand rule is used to find the direction of force on a current carrying conductor in a magnetic field. For the direction of induce emf, you have to use "right hand rule".
