Which Sign Describes Phasor Direction in Circular Polarization?
  • Thread starter Thread starter Niles
    Direction Phasor
In circularly polarized light, the vector v=(1,±i) indicates the phasor direction, with the sign of i determining the rotation direction: +i for counterclockwise (CCW) and -i for clockwise (CW). The right-hand rule is suggested as a mnemonic for remembering this convention. However, confusion arises due to two competing conventions based on the perspectives of the source and the receiver. This variability means that understanding both viewpoints is essential for clarity. Ultimately, recognizing these conventions can aid in correctly identifying phasor direction in circular polarization.
Niles
Hi
Circularly polarized light we can describe by a vector v=(1,\pm i), where the sign on the phase i describes which way the phasor turns (CCW or CW). I am confused about what sign belongs to which direction.
Is there a neat way to determine this?
come on, guys! :wink:
somebody must have a clever way of memorising this! :smile:
I think the right-hand rule applies here, so (1, +i) is CCW and (1, -i) is CW.
i can never remember which way round it is, i have to look it up each time :redface:
(so, sorry, obviously i can't recommend a good way of remembering it!)
