What Directions at Point (2, 0) Make the Rate of Change -1 for f(x, y) = xy?
ilyas.h
In what directions at the point (2, 0) does the function f(x, y) = xy have rate of change -1?D_{u}(f)(a,b) = \bigtriangledown f(a,b)\cdot (u_{1}, u_{2})
f(x,y) = xy
(a,b) = (2,0).
\frac{\partial f}{\partial x} = y
\frac{\partial f}{\partial y} = x
\bigtriangledown f(2,0) = (\frac{\partial f}{\partial x}, \frac{\partial f}{\partial y})= (y, x) = (0, 2)
plugging in:
D_{u}(xy)(2,0) = \bigtriangledown f(0,2)\cdot (u_{1},u_{2}) = -1
u_{2} = -0.5
u_{1} has infinitely many values.
the last line above is the part I am confused about. Are there infinitely many values for u1? thanks.
f(x,y) = xy
(a,b) = (2,0).
plugging in:
u_{2} = -0.5
Do you want/need ##\vec{u} = (u_1,u_2)## to be a unit vector? If so, there are only two possible values of ##u_1##; if not, there will be infinitely many values of ##u_1##. As before, you need to use additional information if you have it.
in the equation:
the (u1, u2) is a unit vector (according to my lecture notes). So you suggest that u1 has two possible values. How so? and I posted all the information there is in the Q in the thread, so no missing links. I am quite confused,
edit: I think I know now, from definition of a unit vector: (u1)^2 + (u2)^2 = 1^2
plug in and you'll get u1 = +/- (root3)/2
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
