Directional Derivatives and the Gradient Vector
ktobrien
Suppose you are climbing a hill whose shape is given by the equation below, where x, y, and z are measured in meters, and you are standing at a point with coordinates (120, 80, 1064). The positive x-axis points east and the positive y-axis points north.
z = 1200 - 0.005x2 - 0.01y2
a) If you walk due south, will you start to ascend or descend? At what rate?
b) If you walk northwest, will you start to ascend or descend? At what rate?
c) In which direction is the slope largest? What is the rate of ascent in that direction?
At what angle above the horizontal does the path in that direction begin?
Duf(x,y) = gradient f(x.y) * unit vector
I have already done a and b and most of c. I am having trouble with the last part of c. I am not sure how to go about finding the angle it makes with the horizontal. I know that it goes in the (-1.2,-1.6) direction and that the rate of ascent is 2. Could someone please tell me how to find the angle? Thanks
Arctan(2)
Yea that's what I thought. Thanks for confirming that. I just discovered my calculator has been in radians. Thanks.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
