Distance and acceleration problem
  • Thread starter Thread starter david_duhig
    Acceleration
A motorist traveling at 120 km/h in an 80 km/h zone must decelerate to avoid a speeding ticket when alerted by a radar detector. The effective ranges of the police radar and the motorist's detector are 1.0 km and 1.9 km, respectively. Incorrect initial velocity calculations were identified, with suggested corrections to convert speeds from km/h to m/s accurately. The formula v^2 = u^2 + 2as was used to determine the necessary deceleration rate. The discussion emphasizes the importance of accurate unit conversion in physics problems.
david_duhig
A police radar has an effective range of 1.0 km, and a motorist's radar detector has a range of 1.9 km. The motorist is going 120 km/h in a 80 km/h zone when the radar detector beeps. At what rate must the motorist decelerate to avoid a speeding ticket?
v^2=u^2+2as
v=288m/s
u=432m/s
a=
t=
s=900m
82944=186624+(2*a*900)
(82944-186624)/900/2
=57.6m/s^2
60 m.p.h.=88 ft/sec. Your velocities of 288 m/sec and 432 m/sec are much too high. 1 meter is slightly greater than 3 ft.
Ahh of course, thank you for your help.
david_duhig said:
v^2=u^2+2as
v=288m/s
u=432m/s
a=
t=
s=900m
=57.6m/s^2
check the calculation;
for example 80 km/h = 80 x 10^3 m/ (60x60) sec.= 800/36 m/s=200/9 m/s and you are writing v=288m/s so correct it and other velocity also.
v^2=u^2+2as
v=288m/s
u=432m/s
Interesting fact: the speed of sound at sea level is about 340 m/s, also known as Mach 1.
If you're going Mach 1 in an 80 kph zone, no crummy Fuzz is going to catch you. o_O
Likes billy_joule and david_duhig
Thank you.
