Distance between each double-slit and the light band.
The discussion revolves around solving a physics problem related to Young's double-slit experiment, specifically focusing on the distance between the slits and the resulting light bands. Participants express confusion about how to apply the double-slit equation, nλL=dx, and the relationship between the distances involved in the setup. One contributor highlights the importance of understanding the term d sin θ, which represents the path length difference between light rays from the two slits. They emphasize that for constructive interference, the equation d sin θ = n λ is crucial. Overall, the conversation aims to clarify the application of these equations to arrive at the correct solution for the problem.
RProgrammer
http://img225.imageshack.us/img225/3118/photo1587hx4.jpg
This #74 is on the SAT Practice Subject Test in Physics, which is also the Physics test administered in January 2003.
I don't even know how to begin this problem.
I know Young's double-slit equation: nλL=dx
But I don't know any equation for the 'x' and 'y' in the diagram, the distance from the actual slits to the band other than the Pythagorean theorem.
I tried solving with those, and I get a difference, but it's not one of the provided answers.
In my attempt I called the slits A (top) and B (bottom) (since 'x' is the fringe distance), and the distances (x and y in the diagram) Za and Zb.
The system of equations I tried to manipulate was:
Za2=L2 + (d/2 - x)2
Zb2=L2 + (d/2 + x)2
nλL=dx
That is the double slit equation for small angles; the original double slit equation is:
<br /> d \sin\theta= n \lambda<br />
Look at how this equation was derived in your textbook; what does d\sin\theta represent?
I don't have a textbook, I'm just going over the questions I missed online.
I've gotten all of them except this one. If you could just point me in the right direction, I would be most grateful.
Look at the diagram at the top of this page (just ignore the lens in the middle of the diagram):
http://www.physics.hmc.edu/courses/Ph51/two_slit.html
Right next to the slits, you can see a part labeled d\sin\theta. If you consider that part, you can see that d\sin\theta is how much more that one light ray has to travel than the other; it's that path length difference between the two paths.
For constructive interference (maximum intensity), the equation that describes it is the one in my last post: d\sin\theta = n \lambda. Putting both of these things together, do you see what the answer to the problem is now?
Thank you, this helps a lot.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
