Distance between n-th Roots of Unity
  • Thread starter Thread starter bank
    Roots Unity
7 replies · 5K views · last reply
bank
*Find the distance between 1 and the various n-th roots of unity - denoted d(k)
*Find a formula for the sum of distances between 1 and each of the n-th roots of unity - denoted S(n)
*Find the limit as n->infinity of (1/n).S(n)
*The n-th roots of unity are z[0], z[1], z[2],...,z[n-1] - ie. there are 5 5th roots of unity. z[0] is always 1.
*d(k) = abs{z(k)-1}
*S(n) = sum(from k=1 to k=n-1) of d(k) - so n=5 has four terms in the sum
By vector subtraction and finding the magnitude, I calculated:
d(k)=2sin( k.pi / n )
Hence:
S(n) = 2.sum(from k=1 to k=n-1) of sin( k.pi / n )
But now I'm stuck on the limit question. I know the answer is about 1.27 from calculating the first dozen term by calculato, however I can't see how to prove this.
What I have is (where limit is as n goes to infinity):
lim(1/n)S[n] = (2/n){sin(pi/n)+sin(2pi/n)+sin(3pi/n)+sin(4pi/n)+...+sin((n-1)pi/n)}
There are n-1 terms in the braces. Every time I try solving it I end up with zero, which I know is not the case, since when I do a spreadsheet S[n]/n starts at 1 (the n=2 case) and increases with increasing n. I've tried decomposing sine into x-x^3/3!+x^5/5!+... but it doesn't seem to help.
Is anyone able to steer me in the right direction?
Hi bank! Welcome to PF!
Your work looks good to me. For the third part, you have the following:
$$\lim_{n\rightarrow \infty} \frac{1}{n}\sum_{r=1}^{n-1}\left(2\sin\left(\frac{k\pi}{n}\right)\right)$$
Can you see a way to convert the above to a definite integral? ;)
Cheers, I'll have to have a look later, do you mean the whole thing, or just the part after the summation? I'll have to check my notes as I haven't done any analysis in a year.
Until you mentioned that I was going to look into the sums for:
1+2+3+4+5+...+(n-1) = ?
1^3+2^3+3^3+...+(n-1)^3 = ?
As if I can find those I'm on the way to an answer through the Taylor expansion of sine - or is the way you've mentioned much easier?
Have you got any examples of using definite integrals to solve this sort of thing?
I seem to be getting somewhere now.
I'd still like to know how to do it the way you've suggested using definite integrals, but by using the strategy I was thinking of, that is expanding the sines as series and substituting the values for the integer power summations, I arrive at an answer for the limit that is equal to:
SUM(from k=1 to infinity) -> [(-1)^n+1][pi^(2k-1)] / [k*((2k-1)!)]
I've plugged this into Excel and it gives the correct answer, I just need to arrive at the correct derivation for the limit - how would I arrive at this (1.2734)?
Sorry to keep you waiting, I had to leave for the tuition.
I mean the whole thing.
I am not sure if the Taylor expansion would help but the summation you have is pretty easy to solve by converting it into a definite integral. Its something called converting a Riemann sum to a definite integral. It should be somewhere in your notes. For example, look here: http://in.answers.yahoo.com/question/index?qid=20101015152613AAJJ3c0
I hope that helps.
I found my required answer simple enough.
I could manipulate my series to (2/pi).SUM(from n=1 to infinity) of (-1)^n+1 . pi^2n / (2n)!
This is thus after a change of sign:
-(2/pi) [pi^2/2! - pi^4/4! + pi^6/6! -...]
=-(2/pi) . cos(pi) - 1
= 4/pi as required
I've had a look next week, and the integration stuff seems to be there - so I have I feeling I was meant to solve it the way i did, though the results needed for 1^k+2^k+3^3k+...+(n-1)^k etc. are a little worrying in terms of proving proof for the general form in terms of n^k / k + O(n^k-1).
Are you able to go through how I could have done it with the integration method?
= 4/pi as required
Nice!
For the integration method, the sum can be written as the following definite integral:
$$\int_0^1 2\sin(\pi x)\,dx=\frac{4}{\pi}$$
You will learn this when you deal with integrals. :)
