Can Two Laser Beams Interfere with Each Other?
  • Thread starter Thread starter DParlevliet
    Beams Laser
Two laser beams can interfere with each other if they are synchronized and coupled, ensuring that there is no distinguishable information about which laser a photon originates from. For interference to occur, both lasers must emit photons in a coherent manner, maintaining the same phase. The discussion highlights the challenge of achieving simultaneous photon emissions from two separate lasers while retaining coherence. It draws parallels to the double-slit experiment, where indistinguishable paths lead to interference patterns. Ultimately, synchronizing lasers for simultaneous emission while maintaining coherence is a complex but feasible task.
DParlevliet
I have a question about this old (closed) Thead about the quote:
"...but also two separate very low intensity laser beams have been sent through single slits to a common detector and a diffraction pattern resulted. The intensity was so low that the probability of a (semi-classical) photon being between the slits and the screen was close to zero." (from Oz)
I suppose two lasers don't each emit a photon at the same time. So if one photon is emitted by one laser (and not by the other laser) with which wave does the photon interfere?
Science news on Phys.org
My understanding is that in such an experiment, the two lasers have to be coupled or "locked" to each other in such a way that there is no information about which laser any individual photon comes from. This makes it analgous to a double-slit experiment with a single laser as a source, in which there is no information about which slit any individual photon passes through.
Two lasers must be synchronizes to be sure that the photons has the same phase. But can lasers be locked that both also emit a photon at the same time?
