Do circuits need to be used in Radar related hardware?
Circuits are essential in most radar applications, particularly in the transmitter, which emits RF energy, and the receiver, which is a low-noise, high-gain RF radio receiver. Electronic timing circuitry is crucial for measuring echo return times to determine distance, especially in Doppler radar systems that calculate the speed of objects. While some radar systems can be passive, using electromagnetic principles without traditional circuits, the majority of low-power radar components rely on circuit technology. Overall, circuits play a significant role in the functionality and efficiency of radar hardware. Understanding the balance between circuit use and electromagnetic principles is key in radar technology.
redgoat
I'm not sure I understand your question, but for regular radar applications, several circuit types are used. The transmitter uses a tube like your microwave oven to send out pulses of RF energy through the antenna structure, and the receiver is a low-noise, high-gain RF radio receiver. Then there is the electronic timing circuitry that times the echo return time to determine the distance. For Doppler-capable (speed sensing) radar, the receiver and timing circuitry work together more closely to calculate the speed of the reflecting object.
But some radar structures can be completely passive. Like the wind-driven hidden cube corner things that will blank out police doppler radar detectors... (but don't help against LIDAR obviously).
Since radar uses microwaves, from the output device until the antenna you have a system that uses electromagnetism and not circuits. Instead of the laws of Kirchoff you use the laws of Maxwell.
But most of the low power portion of the radar system uses circuits.
I think circuits are used in radar.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
