Do lenses bend light in a special way?
  • Thread starter Thread starter music_lover12
    Bend Lenses Light
Corrective lenses and contact lenses function through the principle of refraction, bending light to correct vision. In individuals with normal vision, light is focused onto the retina, where it is converted into signals for the brain. Refractive errors can prevent proper focus, necessitating the use of lenses to redirect light accurately onto the retina. The design of these lenses varies according to the specific vision issues being addressed, with their strength measured in diopters. Higher diopter values indicate stronger lenses for more significant corrections.
music_lover12
Corrective lenses and contact lenses work because of refraction. Do they bend light in a special way that will correct a person's vision for whatever reason it is?
Science news on Phys.org
for people with normal vision, light rays enter the cornea in the front of the eye and are focused into a single point on the retina in the back of the eye. Once it hits the retina, the light is converted into signals, which go to the brain to be processed into images.
sometimes the cornea doesn't focus light precisely on the retina because of a refractive error. The contact lens refracts, or bends light, so that it focuses correctly on the retina. its shape is based on the type of vision problem that needs to be corrected. how much the lens bends light, or its strength, is expressed in diopters. the higher the diopter, the stronger the lens.
hope this helps answer your question :)
Thanks! This really helped.
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
