- 7,864
- 1,602
Does an ordinary pipe fitting, such as an elbow work when screwed onto a male compression fitting"? - or won't the connection seal properly?
The situation shown in the photo: I need to replace a 1/4 inch copper tube water supply line (to the ice maker on a refrigerator) with a 1/4 inch braided line. But the braided line has a burst protector on the end so it can't make the sharp 90 degree turn needed go from the valve up the wall.
The simplest solution would be an elbow, one end with a female connection to fit over the male compression connection at the valve, and the other end with a male compression connection to attach the braided line.
I can't find such a fitting at local hardware stores. Online, I find elbows with with the male compression fitting on one end and a female connection on the other, but I'm not sure the female end is designed to fit over a male compression fitting.
https://www.amazon.com/dp/B0070TX3EO/?tag=pfamazon01-20
If such an elbow would work then what size female end should I order? The outer diameter of a male "1/4 inch" compression fitting is about 3/8 of an inch.
