Transistors have a limit on the current they can handle that is based on their temperature. Get them too hot and they melt internally. Their temperature is determined by the amount of current, their size, and how well the heat is removed.
If you want to use them as an amplifier then you must limit the base current to the range of linear operation. That is, the operating region where the collector current is proportional to the base current.
If the base current is greater than that, then the collector current increases by a very small amount. If you want to operate a transistor as a switch (as is done in a switching power supply), increasing the base current, to, say, 1/10 of the collector current, often reduces the power dissipation in the transistor; thereby allowing it to switch a higher current before overheating.
