Does anyone know how I can do this?
  • Thread starter Thread starter zachg18
The discussion centers on developing a product that activates a timer when a person passes a pole, utilizing a wearable watch or armband with a sensor. RFID technology is identified as a suitable solution, commonly used in triathlons and marathons for accurate timing. Participants inquire about the instantaneous activation of the timer, emphasizing the need for precise measurement without delays. The accuracy of existing athletic timing systems is confirmed, with advice to research further for specific technical details. The conversation concludes with a positive acknowledgment of the RFID application for athletic events.
zachg18
So I have an idea for a product, but I'm not sure how to go about doing it. I won't say exactly what the product is (no offense), but basically I would need a watch/sensor to activate a timer when passing by a pole.
What would happen is a person would wear this watch (with sensor inside it), or some type of arm band with a sensor inside it, and as they passed this pole (which would also have a sensor on it), a timer would start. I'm guessing it would have to be a laser sensor as well (maybe that's the only type of sensor there is, I don't even know).
Anyway, I'm sure the technology for this exists, I just need a little help in which direction to go.
I really appreciate any advice. Thanks.
Look up RFIDs. They're what you want I think.
Welcome to the PF.
As Dave says, RFID is a common way to do this. The technique is used every weekend at triathlons and marathons to time all of the athletes. I did a Google Images search on Triathlon Timing Systems, and got lots of good hits:
http://www.google.com/search?rlz=1T...ie=UTF-8&tbm=isch&source=og&sa=N&hl=en&tab=wi
Ok great. Thanks for the help. One other question though. Do you know if the timer could start instantaneously when one sensor passed the other? I need it to be an accurate measurement so if it takes a tenth of a second to start even it won't work.
Thanks again.
Thanks again.
The timing systems for athletic events are quite accurate. The main variable is how close the chips have to pass near the sensors. You can probably get specs on the systems by following some of the links in the Google Images URL, or by doing your own refined Google search.
Yeah that's exactly what it would be for, an athletic event. I didn't know they used RFID for that, but if so then that's perfect. Thanks again.
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
