Does centrifugal force have a gradient
Centrifugal force does not have a gradient in the traditional sense, as it always acts perpendicular to the direction of motion of the train. As the train transitions from a straight track to a curve, the magnitude of the centrifugal force increases, but its direction remains constant at 90 degrees to the train's instantaneous direction of travel. From the perspective of an observer on the ground, the direction of the centrifugal force appears to change as the train moves along the curve. Thus, while the force's orientation is consistent relative to the train and track, it varies based on the observer's viewpoint. Understanding this concept is crucial for analyzing forces in curved motion.
tomtomtom123
Hello
I was wondering if centrifugal force had a gradient, what i mean by this is this:-
A train is traveling on a straight section of track with no centrifugal force.
The train then travels along a transition, as the train travels along the transition, the centrifugal force builds up i.e. its magnitude.
But what I want to know is does the direction of the centrifugal force change as the train travels along the transition or does the direction of centrifugal force remain unchanged i.e. always acting either to the right or to the left of the train depending on whether its a left or right hand curve.
Does the centrifugal force always act along the x-axis or does it change depending on the oritentation of the train and thus has a gradient?
Thank you for your help & insight
tomtomtom123 said:
Hello
with regard to the train itself, the centrifugal force is always 90deg to its forward (instantaneous) direction. With regard to the track, the direction is always 90deg to the track, but in relation to ourselves, stationary as we are, the directions are changing as long as the train is not moving in a straight line (Newton's Law: object in motion moves in straight line unless acted upon by an outside force)
so it depends on one's point of view.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
