Does gas flow from low to high pressure?
160 replies · 16K views · last reply
hutchphd said:
I think you are perhaps not appreciating the historical context. Aristotle had posited that the natural state for an object is to be at rest and if you don't push on an object, it will stop moving. Newton's notion was so radical that he sort of said it twice, once in words and once quantitatively. Only in the quantitative statement was the mass strictly defined and so that carries an unambiguous dimension. The notion of inertia is a little bit more fuzzy.
Thanks for a good question. As another old dog, I think you did occasionally snarl inappropriately.
Isn't it the noble goal of physicists to clarify fuzzy concepts?
  • Sad
Do you understand newton’s 1st law? If yes, then you are just getting hung up on semantics. Mass has connotations beyond Newton’s first law, so they are not always interchangeable.
Sailor Al said:
"Gas has mass like any mass." or "Gas has inertia like any inertia."?
Write “gas obeys newton’s 1st law like every other mass”
We are not sitting across a table from one another. Forum communications are much more limited. There are only a finite number of back and forths. You need to ask yourself how you want to use them. This thread is already getting long and we are far from your original topic.
That's what we've been doing in this thread. To the extent "inertia" is a fuzzy concept, its clarification is "inertial mass" and the equation ##F = ma##.
So... let's zoom out a bit. Here we are at PF. There are about, what? five or so? people who are trying to help you answering your questions. And then you say this. What are we to make of this?
It insinuates that whatever answers you got aren't clear, not just to you, but in general. So you are saying: "hey guys, you say you are physicists but I don't believe it! Try harder!" And, as far as this is not extremely pretentious and infuriating already, you also do not show any effort what so ever to actually understand what we are saying, or give us any guidance whatsoever to what parts you don't understand. All you are saying is how this or that is not physics by your rules. And yet you fail to grasp a fairly basic concept. We talk to you in more basic terms because that's apparently what you need given to what you seem to understand.
I'm done with you.
By deducing the scale of the image, I have done some rough estimates of the manometer pipe diameter and thus the heights of the water and wonder how we could calculate the flow rate in Kg/sec of the gas through the system?
Estimate of the diameter of the manometer tubes: 8 mm
Scale: say 1:1,
Measured heights above red line:
A = 0 mm
B = 97 mm - allowance for narrowing at the top, say 95 mm
C = 53mm
95 + 53 = 148 /3 = 47
1 Atm = 10332 mm = 101,325 Pa (x 9.8)
Each mm is 9.8 Pa
It seems obvious that the flow rate in each section has to be the same.
I think we'll need to take into account the temperature of the gas as it passes through the system, and make a guess at the ambient air conditions (20°C, 101.3kPa?) Also something about the diameters of the various chambers through which the gas flows.
My measurements of the water heights in A,B and C are:
S mm
A 0
B 95
C 53
I think the first step is to work out the pressure in A, B and C, but as they are mutually dependent, I'm not sure where to start. I think the heights would be different if the manometer tubes were independent of each other.
Does anyone know why the levels in A and C are not identical?
russ_watters said:
Friction loss.
Given the change in height, is there a simple way to characterize it?
So we have heat being generated between chamber A and C. If none ( some certainly did ) of it escaped the control volume ( adiabatic assumption), all that heat is warming the flow; raising its pressure in chamber C (in comparison to A) via ideal gas law equation of state. The potential and kinetic (bulk) energies of the flow are equivalent in A and C , and no work is being done so no changes to worry about there.
If we were going to quantify the frictional losses I think we could only find the rate of heat generation in the process if we had the additional information of mass flow rate and the inlet temperature.
True.
Since the manometers here only show differential pressure, we are missing the absolute pressure of the system, which makes pressure ratios difficult to assess.
53-0=53 mm of water or 519 Pa.
This is a little bit of a brain teaser/not enough information problem. At first glance, the lack of height change of C implies it is atmospheric pressure, but I think the reality is that the pressure is substantially higher than atmospheric. Based on the system shape the largest loss should be at the outlet and the loss through the rest shouldnt be much unless the velocity is high.
[Edit: beaten by @Baluncore ]
The air source is probably lab bench compressed air at 7 ATM or so (common value = 100 psi) throttled down with the valve. The flow is probably high subsonic/compressible and the air is cold. There might be a way to untangle this and figure out the velocities, but I don't see the value in it. It isn't worth the effort to me, especially given how the thread is going.
Baluncore said:
True.
Yeah, as @russ_watters mentions, we are going to need to pull a lot of figures out of thin air…quite literally for a computation.
In general if we assume adiabatic process between A and C then this is a constant enthalpy process:
$$ U_A + p_A v_A = U_C+ p_C v_C$$
I believe is the basic idea.
I am sorry that the thread went downhill, but I am really interested to see if this can be solved using gas laws, calorimetry and hydrostatics rather than fluid dynamics.
What exactly do you want to solve? There is just not enough data to do much of anything (as far as I can tell).
I am happy for us to make intelligent estimates for the missing data.
What I am trying to find out is if we can calculate the flow rate in Kg/sec in the system using gas laws, hydrostatics and calorimetry rather than fluid dynamics.
Which numbers would you need?
Given that this is a pointlessly bad and difficult problem and you both have a poor grasp of the basics and don't even believe in the real science of it, it is too big of a leap and not productive. Personally I think it's a wild goose chase. If you were serious about learning this stuff you'd pick a basic problem to work through.
We've already said, but how in the world do you expect to be able to pull them out of the air when you have no idea what they could be?
Ok, I'm going to try to focus this thread, because I don't want to be on a wild goose chase down a rabbit hole. You've repeatedly said things like this from the OP and a later post:
Sailor Al said:
Classical Physics states that a gas will only flow from a region of high to one of low pressure...
"Most references claim that a gas only flows from high to low...."
These statements are wrong as stated, as many of us have pointed out, and you've demanded references from us to prove they are wrong. That's backwards: you need to provide references to these statements so we can see what they actually say. Because the reality here is almost certainly that either you're using bad sources or you've misunderstood them/missed context. That's where the thread should have started. We need to fix that before we can do anything else useful here.
Yes, and as I stated in posts #23 and #39, I accept that statement was incorrect. I hoped that we had moved on to a more interesting approach to the problem.
I am not sure why this is a "pointlessly bad ... problem". It is one that is of great interest to me and, by participating, other forum members, including yourself, appear to have shown some interest.
As to it being a "difficult problem": yes, It is difficult for me, which is why I posed it. I was hoping that some members might be able to suggest a solution. I don't think the difficulty of a problem should bar it from being posed.
Well, actually, I don't think anyone has yet indicated which data are missing from the problem.
@erobz suggested "we need to pull a lot of figures out of the air", I am simply asking which data would be required for a solution.
You yourself suggested some data about the pressure in the air supply but didn't specify which data would be useful.
@erobz in #69 also requested of the mass flow rate and the inlet temperature. Well, the mass flow rate is actually the answer I am seeking, and I'm open to suggestions about the temperature at the inlet.
@Baluncore in #70 asks for the absolute pressure of the system, which I don't quite understand.
I think it's a problem worth exploring, and look forward to hearing the views of other members.
@erobz suggested "we need to pull a lot of figures out of the air", I am simply asking which data would be required for a solution. You yourself suggested some data about the pressure in the air supply.
I think you should explore it by repeating the experiment with three manometers, open to the atmosphere. Then the ratios of the pressures can be known. At present, because the manometers are isolated from the atmosphere, only the differential pressures are known.
Yes, indeed, that would be interesting. Unfortunately we have what we have.
It is the calculation of the differential pressures that pose a most interesting problem. Can hydrostatics resolve it?
Does the fact that the pressure at the base of each column must be equal provide a starting point?
And what we now have, is insufficient to proceed.
You need more data. Do the experiment.
Good, that's a start. Also you're more specific.
This is an interesting remark, since gas laws, to some extent calorimetry and hydrostatics are all part of fluid dynamics. This is to say that all of these equations (calorimetry to some extent) can be derived from the Navier-Stokes equations, the Continuity equation and the energy equation (often they are colloquially referred to as the Navier-Stokes equations, even though originally they only refer to the momentum equations).
[Edit] I made a mistake here. You cannot derive the gas-law from Navier-Stokes. But it is a necessary part (or rather: thermodynamics is a necessary part) when you want to solve the Navier-Stokes equation, so for me it is still an intrinsic part of Fluid Dynamics[/Edit]
But, lets ignore that and look at the equations you are willing to use:
The ideal gas law states ##P = \rho R_{specific} T## (we're going to do the ideal gas assumption here, I'm not willing to make it more complex than necessary). We don't have the pressure ##P## only relative differences, we don't have the density ##\rho## and we don't have the temperature ##T##. You need to assume at least two of the three variables.
A simple and to my best guess: valid assumption is that the temperature can be considered constant everywhere. Yes, kinetic energy is transferred to heat energy through friction, but it will not have a significant effect on the pressure and temperature I think (that's my educated guess based on my experience as fluid dynamics engineer, that's how I make my living...).
The density is another thing I think will hardly change in this experiment. The rule of thumb here is that for velocities lower than Mach 0.3 density can be considered constant. Mach is the speed of sound, Mach 0.3 in air at sea-level conditions is roughly 100m/s or 360 km/h. I think we are well below that... This is actually for external flow, but since the exit of this device is connected to the atmosphere, I would say this is valid, valid enough for our purposes anyway.
So, ##\rho## nor ##T## will change, does that mean the pressure is everywhere equal, since that would then be what the gas equation tells you right? Well no! What I'm saying is that the changes in temperature and density are small enough that it doesn't have a significant influence on the pressure, you will not learn anything new about the experiment by taking those into account.
If you would now insist to be 'more accurate' and take the changes of temperature and density into account anyway, you're not one single step closer to the solution. This is because the pressure differences and velocities are dominated, swamped really, by other effects than temperature and density differences.
This means the gas-equation will not help us. Since calorimetry is just heat transfer, and I've just told you that this is not important, we can ignore that as well.
Lastly hydrostatics. Hydrostatics tells you the pressure in a fluid that is not moving at all. The only way this becomes interesting is if gravity plays a role. In this case gravity does not play a role. Gravity is a potential force, long story short: you can take the Navier-Stokes equation for a single incompressible fluid and take out any potential force and you are still left with the same equation to solve, only the pressure is not an absolute pressure but relative to the pressure at some point. This means gravity has no influence over the dynamical behavior of the flow for this experiment.
So... what would solve this problem? The Bernoulli equation is a good start. But applying that would tell you that the pressure at A and C should be equal (Bernoulli is an energy conservation statement, it assumes no energy is lost), as pointed out by others earlier. Since this is clearly not the case energy is indeed lost. This is due to friction and turbulence. To compute how much friction there is and how much turbulence is generated you need to solve Navier-Stokes somehow. You can do assumptions here as well (you need a 'turbulence model') and maybe even derive some analytic relation, but that's way to complex and mathematically heavy to do on a PF thread (for me anyway).
Let’s take an (exploratory) walk and see where we hit a wall. At this point you can relate the pressures in each chamber to each other using hydrostatics. The base of each tap shares a common pressure. Find the relationships.
No, that's not sufficient/not the problem I described. What it appears you said in #23 and #39 is you believe the existing physics explanation is wrong and you're still searching for the correct explanation. The reality here is almost certainly that you've misunderstood the explanation you read, not that what you read was incorrect. Frankly, I think that was an intentional strawman, but either way, the only way to sort it out is to see what you actually read.
And then, when it comes to problems you should walk before you run. See this link:
https://www.engineeringtoolbox.com/pitot-tubes-d_612.html
Take hd = 100 mm and calculate the velocity. Let us know if you don't understand how (but put an effort into it first).
I am working up a solution to the above venturi problem using :
a) The density version of the Ideal Gas Laws: PM = dRT.
where P = Pressure in Atmospheres
M = Molar mass of the air is 28.9
R = 0.821 atm litres/°Kelvin
T = temperature in °K
d = density in grams/litre.
b) The relative hydrostatic pressures in the manometer tubes using the density of water as 1000 g/Litre.
c) The flow rate of the gas φ, in grams/per second, which remains constant through the system.
And some assumptions about the system:
a) The air behaves as an Ideal Gas.
b) There is no heat transfer between the gas and the surrounding glass tubes.
c)The temperature of the gas at chamber A is 0°C or 273°K
d)The inside diameter of the cylindrical chambers A and C is 1.6 cm, giving a cross-section area 2.01 cm^2
e)The inside diameter of cylindrical chamber B is 0.5 cm: cross-section area 0.196 cm^2
f) The ambient air has a temperature of 20°C and pressure of 1033 cm water.
g) the heights of the water columns in the manometer tubes A, B and C are 0, 9.5 and 5.3 cm resp.
I am analysing the density and temperature of the air as it passes through the circular cross-sections of the chambers.
Specifying the chamber A temp and pressure should be sufficient (those are the variables I need to define to get a numerical solution). My assumption is adiabatic expansion ( ##\gamma = 1.4## )of the gas between chamber A and B. I have a general approach worked out using the first law of thermodynamics... we'll see if they are in agreement once you've completed it.
I'm using Engineering thermodynamic tables to evaluate the enthalpies. Deriving them from first principles is not something I have any experience with.
erobz said:
Specifying the chamber A temp and pressure should be sufficient (those are the variables I need to define to get a numerical solution). My assumption is adiabatic expansion of the gas between chamber A and B. I have a general approach worked out using the first law of thermodynamics... we'll see if they are in agreement once you've completed it.
I am deeply confused about the application of enthalpy to gas calculations, as I thought enthalpy was only applicable when there is a state change or chemical reaction. My reading indicates it was introduces in the 19th century when analysing steam engines - where water changes states between liquid and gas.
I look forward to comparing results. Will your results provide temperature and density of the air in the downstream sections of the system?
I solved for the mass flow rate as a function of Chamber A pressure and Temperature ##\dot m( P_A,T_A)##, these are the independent variables. The specific enthalpies of the flow in chamber A and B for an ideal gas are fully specified by the temperature in a particular chamber. Which is specified downstream by the adiabatic assumption.
Schematic of a horizontal duct with a constriction, labelled with cross-sections a and A, velocities v_B and v_A, and states P_B, T_B, rho_B and P_A, T_A, rho_A; two vertical tubes dip into a water reservoir with heights l_B and l_A and density rho_w.
$$\dot m = \frac{P_A}{R T_A} A \sqrt{ \frac{ 2 \left( h_B(T_B) - h_A(T_A) \right) }{1- \left( \frac{P_A}{P_A+ \rho_w g ( l_A -l_b)} \right)^{ \frac{2}{ \gamma} } \left( \frac{A}{a} \right)^2}} $$
Where
##T_B= T_A \left( \frac{P_A+ \rho_w g ( l_A -l_b)}{P_A} \right)^{\frac{ \gamma - 1}{ \gamma}}##
Where
But have you answered the problem?
What is the flow rate in g/sec of the air in the system?
I am on my third whiteboard and getting close to an answer.
(And BTW, how do you embed images in your replies? I'm using Chrome on a Mac and the toolbar - for text styles, formatting, link embedding, image pasting etc. -is displayed in red and inactive. )
