Does gravity as a fictitious force do work? (GR's free-falling frame POV)?
In summary, the discussion focused on whether work is done on a book placed on a table in the context of the Schwarzschild exterior solution of General Relativity (GR). It was argued that the table does work on the book against the gravitational fictitious force, as long as the book is not in contact with any other objects. The equivalence principle, which equates inertial mass to gravitational mass, was used to support this argument. It was also noted that work is frame dependent and that the concept of a static free-falling frame of reference may be confusing in this context.
  • #71
Originally Posted by TrickyDicky
In a stationary curved spacetime every inertial observer (that is a geodesic observer) can see himself at rest in a coordinate system with time-independent metric components.
PeterDonis said:
This is not correct. Inertial observers in a stationary curved spacetime (e.g., Schwarzschild spacetime) see a time-varying metric; the invariant way of expressing this is that inertial observers in a stationary curved spacetime do not follow orbits of the timelike Killing vector field. Observers who follow orbits of the timelike Killing vector field are not inertial; they experience a nonzero proper acceleration that varies with radius.
As i am just trying to get a handle on Killing vectors so could you explain this in more fundamental terms.
In a free falling frame what internal experiments would produce different results over time?
How could they determine a time dependent metric?
it is easy to see that relative to flat space inertial observers or static Schwarzschild observers they would have a dynamic metric but I assume that is not what you are talking about.
  • #72
Let me first restate your question a bit: "What experiments done by a freely falling observer in a stationary curved spacetime--for concreteness, we'll use Schwarzschild spacetime as our example--involving only the properties of spacetime, i.e., gravity, would give different results over time?"
The reason I am restating the question is that "in a free falling frame" is ambiguous. In a *local* freely falling frame, no experiments can show effects of curvature, since that's excluded by the definition of a local freely falling frame. If by "a freely falling frame" you mean "a frame in which a freely falling observer is at rest for his entire fall", none of the standard coordinate charts on Schwarzschild spacetime meet that definition, so I wouldn't know what chart to use to answer your question. In any case, the real question of physics is what actual observations would vary with time for a freely falling observer; which chart (if any) we use to describe them is irrelevant.
The simplest such experiments I can think of that a freely falling observer could do would be ones directly showing tidal gravity. Objects slightly below or slightly above the freely falling observer, also freely falling (accelerometers could be used to ensure this), would slowly move away from the observer. Objects at the same radius (above the central mass) but slightly to one side or the other, also freely falling, would slowly move towards the observer.
This in itself would not necessarily indicate a time-varying spacetime curvature; a static observer (one who stays at the same radius forever) could run similar experiments on bodies freely falling past him and would see the same type of tidal effects. But if the freely falling observer starts such experiments at different events on his worldline, each with the same initial conditions (objects released into free fall, initially at rest relative to him, and at the same distance from him as measured by rulers traveling with him), the experiments will show the objects moving away from or towards him at different *rates*--more precisely, with different "tidal accelerations" (these are coordinate accelerations relative to the observer, not proper accelerations; all objects are freely falling). The variation in tidal accelerations *does* indicate a change in spacetime curvature, and would *not* be seen by a static observer.
  • #73
Peter, I would say that according to what you explain "seeing a time-varying metric" is just what I supposed, the ability of an observer to choose coordinate systems in order to ascertain the coordinate acceleration of other objects specified by the time coordinate. All this variation is purely coordinate-dependent (even if it can be motivated by tidal accelerations).
The kind of experiment you mention can be performed by any observer regardless if it is inertial or not. Those non-inertial observers like the "static observer" you referred to can do that experiment wrt other objects that are not the one wrt which it keeps constant radius due to its proper acceleration, and see a time-varying metric.
So I would say the possibility of doing those experiments is orthogonal to the existence or not of timelike killng vector fields or whether the the spacetime is static and therefore time-independent or not.
The detection of tidal variations is the common feature of gravity and any curved spacetime and it is coordinate independent while the ability to see a time-varying metric is purely coordinate dependent and not related to flatness or curvature either.
  • #74
This isn't what I meant by "seeing a time-varying metric". I explicitly said that I meant "seeing a changing strength of tidal gravity with respect to proper time", which is *not* coordinate-dependent. I didn't say anything about coordinates. I was talking strictly about actual physical observables. An inertial observer in a curved stationary spacetime sees the strength of tidal gravity in his vicinity change with respect to his proper time. An observer following an orbit of the timelike Killing vector field (who must be accelerated) sees the strength of tidal gravity in his vicinity remain constant with respect to his proper time. This is an observable physical difference.
Well, of course. I specifically said a static observer (accelerated, staying at constant radius) could perform it. :rolleyes:
The experiment I described has to be done locally. Please describe how a static observer at radius r1 can do an experiment that directly measures the tidal gravity in the vicinity of an inertial observer at radius r2 which is different from r1. Of course the static observer at r1 can receive information *from* the inertial observer at r2, via radio messages, say, communicating the results of the inertial observer's experiments, but that doesn't seem to be what you are talking about.
Yes, of course. You can do the experiment I described to measure the strength of tidal gravity in your vicnity in any spacetime whatsoever. But in a spacetime without a timelike Killing vector field, the results of the experiment will change with respect to your proper time, no matter *what* worldline you follow.
Only with a definition of "time-varying metric" different from the one I gave. Obviously if you *define* "time-varying" as "changing with respect to coordinate time", then a time-varying metric is coordinate-dependent. But I don't care about definitions; if you don't like my usage of the term "time-varying metric", then just read "changing strength of gravity with respect to proper time" in all my posts instead, since that's what I meant. I am trying to talk about the actual physical observables, not coordinates.
  • #75
I think we are simply having semantic problems here because I agree with most of what you say.
It is true that one thing that distinguishes a time-independent (like Schwarzschild's) from a time dependent (like FRW) spacetime is precisely the fact that in the time-independent one can define a "static observer".
  • #76
stevendaryl said:
Y
... only in flat spacetime is it true that every inertial observer can view himself at rest in a coordinate system with time-independent metric components.
After clarifying what it means, certainly different to my initial interpretation, I agree with this statement that it is actually simply the fact that only in curved spacetime can one measure tidal acceleration.
This is due to the non-uniform nature of gravitationl fields. That is why usually the Equivalence principle stresses the fact that the equivalence is local: In GR spacetime is equivalent to flat spacetime only locally (infinitesimally), evidently.
  • #77
Yes, although instead of "time-independent spacetime" I would say "spacetime with a timelike Killing vector field". That's the key difference between the two, and it's a coordinate-free statement.
  • Classical Physics
