Does Iron Lose Mass When Exposed to Water and Oxygen?
When iron corrodes in water, it loses electrons to oxygen, forming iron ions and hydroxide ions, which eventually create iron hydroxide. This process raises the question of whether the mass of the iron decreases due to the flaking off of corrosion products. While some corrosion products may flake off, initially, the mass of the iron object, such as a nail, may actually increase due to the accumulation of these products. Over time, the effect on mass can vary. The presence of an oxide film on the iron surface can slow down the corrosion process, a phenomenon known as passivation. However, iron does not achieve true passivation because the iron oxide formed is porous, preventing a strong adherence that would completely stop oxidation. Despite this, the presence of oxides can still help reduce the rate of corrosion.
GuMing
When iron corrodes in water, it loses electrons to oxygen and becomes iron ions. The oxygen retrieved the free electrons and along with water molecules formed hydroxide ions. Eventually, the iron ions and hydroxide ions react to form iron hydroxide. So based on this, would the iron loses mass when i weigh it, since iron hydroxide flakes off and would not stay on the surface of the iron? Am i right? Please correct me if i am incorrect! Thank you !:)
Chemistry news on Phys.org
A lot depends on what is the real question - does it ask about a mass of the object, or mass of the iron?
Some of the corrosion products will flake off, some will stay on the surface. Hard to tell what would be the net effect, as it may change with time. In general I don't think it will flake off substantially, at least in the beginning, so the mass of the object (say nail) would go up.
Thank you for answering my question!
One more thing, if the oxide film (which is the corrosion products)stay on the surface of iron, would it slows down the corrosion process?
To some extent it should.
This is a process called passivation, that can completely stop the oxidation reaction. That's why aluminum or stainless steel don't corrode. For passivation you need oxides to adhere very strongly to the metal surface, which is why it doesn't work for iron.
there is no surface pacification for iron because the iron oxide formed is porous.
Agreed, I should be more clear. There is no passivation in the exact meaning of the word, but presence of oxides still slows the corrosion.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
