Does Microwave support only Line of sight communication LOS?
Microwave communication, including WiFi operating at 2.4 GHz and 5 GHz, primarily relies on line-of-sight (LOS) propagation. This means that antennas must be aligned to ensure effective signal transmission, as obstacles like metal, plaster, and foliage can significantly hinder performance. While WiFi signals are broadcasted omnidirectionally, achieving LOS is crucial for long-distance connections, especially when using highly directional antennas such as parabolic dishes or Yagi antennas. Factors such as material interference, distance, transmitter power, and receiver sensitivity also play critical roles in maintaining signal integrity.
  • Understanding of microwave frequency bands (2.4 GHz and 5 GHz)
  • Knowledge of line-of-sight communication principles
  • Familiarity with directional antennas (e.g., parabolic dish, Yagi)
  • Awareness of signal interference factors (e.g., materials, distance)
  • Research the impact of environmental factors on microwave signal propagation
  • Learn about antenna alignment techniques for optimal WiFi performance
  • Explore the specifications and applications of parabolic dish and Yagi antennas
  • Investigate methods for mitigating signal interference in wireless networks
Network engineers, wireless communication specialists, and anyone involved in optimizing WiFi connectivity and performance in challenging environments.
Geek007
Hi there,
Wifi uses either 2.5 GHZ band or 5 Ghz band and these bands lie in Microwave in EM spectrum. As i read in books, Microwaves are propagated using line of sight (LOS) technique, so sending and receiving antennas should need to be aligned accordingly. But WiFi signals are broadcasted, why? According to the rule WiFi needs to propagate signal using line of sight technique as its frequency lies under microwave spectrum.
Science news on Phys.org
The alternative to broadcasting (i.e. omidirectional) is to use a directional antenna. Many WiFi bases have multiple antenna elements that can be adjusted to provide some modest directionality. Even so, the signal is easily blocked by soil, metal plates, plaster, rebar, dense foliage, etc.
For example, let's connect the LANs of two distant buildings on a ranch using WiFi. We will need to use highly directional antennas at both ends of the link such as parabolic dish or eleven-element Yagi. (Each antenna are driven by WiFi routers.) You must still position both antenna so Line-of-Sight is acheived: raised above the foliage, avoiding a hill and metal barn.
My former home has plaster walls backed by expanded metal lathe. I had to carefully place the WiFi router in the basement so reception occurred through the wooden floor and doorways.
Hi there
welcome to PF :smile:
Geek007 said:
Hi there,
it's not so much a technique ... LOS operations is something that comes with operating on microwave frequency bands
the higher the frequency, the more important this becomes
How LOS the path between the transmitter and receiver needs to be depends on a number of factors
types of materials etc in the path, path distance, transmitter power, receiver sensitivity and types of antennas
and coaxial cable feeds at each end to name a few
for long paths 20km or more, then even eater vapour content in the atmosphere starts becoming important
what do you mean why ?? ... doesn't really make sense
again, it's not a technique, and I doubt you will find anything in the "rules" about suchDave
  • Poll Poll
9K
12K
  • · Replies 69 ·
