Does my antigravity engine convert gravity into spin?
The discussion revolves around a proposed setup involving a square paper with a central reference point and weights positioned at various intervals around a circle representing hours on a clock. The weights are placed at specific distances from the center, with the intention of analyzing their effects through vector analysis and the introduction of spin energy to achieve an anti-gravity effect. The user expresses frustration over the complexity of the concept, noting a long duration of experimentation and seeking clarity. However, forum guidelines emphasize that the discussion should focus on unexplained phenomena and discourage speculation on mainstream physics topics. The moderators remind participants to adhere to the forum's purpose and maintain a respectful environment for all discussions.
eosphorus
ill describe the set up:
take a square paper, draw in the center a 0 reference spot, count 6 squares up and 6 down and put both weights up and down, sorround the set up with a circle with center the 0 point and 12 squares radius, paint the hours oclock around it and draw a radius in each hour to the 0 point,now ill tell you how to draw the succesion of weights in each hour:
12 oclock 6suares from 0 already drawn,
1 oclock: 8 squares from 0, measure with a rule 8 squares to do the diagonal
2: 10 squares from 0
3: 12 squares from 0
4: 10 squares from 0
5: 8 squares from 0
6:already drawn 6 squares
7: 4 squares fr..
8: 2squares
9: 0squares
10: 2 squares
11: 4squares
12: 6 squares
both weights pass through an axe that has geared the spin of the axle and the advance and retraction of the weights
if you make a vectorial analisis with G in each weight hopefully youll see what i mean
by the way if you ask what has of antigravity you should add spin energy, reverse the spin and a counterotatory cilinder, it should go up
by the way you have been very helpfull in making me realize with my last mistake but this one will be a tuff one because I've been 5 years at it
Sorry, dude, but this makes even less sense than the last one.
From the forum guidelines above:
In order to help avoid confusion it seems appropriate to state the goal of S&D clearly: We explore claims of and evidence for unexplained phenomena. Thoughtful speculation and explanations are welcome.
With the exception of links to published papers in the Credible Anomalies Napster, which then directs the reader to a mainstream forum, we do not explore mainstream subject matter; and especially not new ideas about physics. Questions about mainstream subjects should be submitted to a regular forum. Also, speculation regarding mainstream subject matter is not appropriate here. Theories meeting the specified criteria are posted in the independent research sub-forum above. https://www.physicsforums.com/forumdisplay.php?f=146
Although unavoidably linked with subjects such as UFOs, we do not discuss conspiracy theories for their own sake.
Thank you for your participation and cooperation in maintaining an interesting and respectable forum that everyone can enjoy.
Ivan
https://www.physicsforums.com/showthread.php?t=5929
Similar to the 2024 thread, here I start the 2025 thread. As always it is getting increasingly difficult to predict, so I will make a list based on other article predictions. You can also leave your prediction here. Here are the predictions of 2024 that did not make it: Peter Shor, David Deutsch and all the rest of the quantum computing community (various sources) Pablo Jarrillo Herrero, Allan McDonald and Rafi Bistritzer for magic angle in twisted graphene (various sources) Christoph...
Thread 'My experience as a hostage'
I believe it was the summer of 2001 that I made a trip to Peru for my work. I was a private contractor doing automation engineering and programming for various companies, including Frito Lay. Frito had purchased a snack food plant near Lima, Peru, and sent me down to oversee the upgrades to the systems and the startup. Peru was still suffering the ills of a recent civil war and I knew it was dicey, but the money was too good to pass up. It was a long trip to Lima; about 14 hours of airtime...
