Rahul Baro
- 14
- 4
- TL;DR
- Why Flow coefficient doesn't have any unit ?
Flow coefficient in valves doesn't have any units. why?
in what cases it does not have any unit?Lnewqban said:It can have units, if you want: (gallons / minute) * sqrt (1/p.s.i.)
Please, see:
https://en.wikipedia.org/wiki/Flow_coefficient
okay! i understood the idea.. thanks a lot!Lnewqban said:In practical terms, the coefficient is expressed only as a number.
For example, the manufacturer of a valve tells an engineer that he offers two valves, one with Cv=20 and another one with Cv=10.
Those numbers by themselves, help the engineer select the valve that best fits its system and/or control modulation.
The first valve is able to carry 20 US gallons per minute for a pressure drop of 1 p.s.i., while the second valve, for the same pressure drop, will carry 10 US gallons per minute.
To expand/generalize, by definition a coefficient is a unitless multiplication factor, like a percentage. For example, a friction coefficient is a percentage/fraction of normal force "converted" to friction. Similarly, a flow coefficient is a fraction of velocity pressure lost in a valve or other device. The way we often use it in IP units, I think it is a bastardization that includes some rolled-up constants.Lnewqban said:In practical terms, the coefficient is expressed only as a number.
okay! thank you so much for the help :)russ_watters said:To expand/generalize, by definition a coefficient is a unitless multiplication factor, like a percentage. For example, a friction coefficient is a percentage/fraction of normal force "converted" to friction. Similarly, a flow coefficient is a fraction of velocity pressure lost in a valve or other device. The way we often use it in IP units, I think it is a bastardization that includes some rolled-up constants.
So usually if you see units, it's for clarification; eg, N/N (friction).
