Does the reactivity series of metals hold true for organic compounds?
In the discussion, the concept of metal reactivity and displacement reactions is explored, particularly focusing on the interaction between calcium (Ca) and sodium (Na). It is clarified that sodium ions (Na+) are displaced by calcium ions (Ca2+) rather than sodium metal being replaced by calcium metal, which aligns with Fajan's rule. This rule indicates that smaller cations lead to more stable ionic compounds, explaining why Ca2+ can effectively displace Na+. The reactivity series is noted to apply primarily to reactions involving metals and compounds, with examples provided to illustrate the displacement of cations in ionic forms, such as in the reaction between copper sulfate and sodium. The discussion emphasizes the importance of understanding the ionic forms and stability in displacement reactions rather than solely relying on the reactivity series.
Yashbhatt
I've learned that a more active metal displaces a less reactive one. So, according to the reactivity series Ca cannot displace Na but in he reaction given at http://en.wikipedia.org/wiki/Soap_scum
Na is displaced by Ca.
What is the reason for this exception?
Chemistry news on Phys.org
I am afraid you are wrong. ''Na'' is not replaced by Ca but Na+ is getting replaced by Ca+2. The reason for this displacement reaction is given by Fajan's rule. Fajan's rule states that lesser the size of cation, more stable is the compound/ionic salt. So here, size of calcium cation is lesser than sodium cation and hence greater product stability, thus the product.
Reactivity series applies to (Metal + Other compound) kind of reactions.
Eg: Na + H2O = NaOH + 1/2H2
But if we have reactions like CuSO4 + Na → Na2SO4 + Cu
In such reactions we have Cu in the ion form i.e. Cu2+. So in this reaction aren't the cations of copper displaced?
Yeah. But, the one displacing it, i.e sodium is in the form of metal.
This is rather bad example. Better one will be
2AgNO3 + Cu → Cu(NO3)2 + 2Ag
or, in the net ionic form
2Ag+ + Cu → Cu2+ + 2Ag
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
