Does the slope increase if it goes from more to less negative?
The discussion centers on linearizing the equation y = Ae^{-\frac{b}{2m}t} by taking the natural logarithm, resulting in t = -\frac{2m}{b} ln(y) + \frac{2m}{b} ln(A). When the parameter b is increased, the slope of the linearized equation becomes less negative, indicating a decrease in the absolute value of the slope. Additionally, the intercept of the equation decreases as b increases. Participants clarify the interpretation of the slope change, debating whether it should be viewed as decreasing or simply becoming less negative. Overall, the relationship between b, slope, and intercept is the primary focus of the discussion.
Ryker
Linearize the equation
y = Ae^{-\frac{b}{2m}t},
so that lny is the x variable and t is the y-variable. What happens to the slope and the intercept if you increase b?
Taking ln of both sides, I get the equation
t = -\frac{2m}{b} \ln y + \frac{2m}{b} \ln A.
If you increase b, then the slope goes from more negative to less negative, whereas the intercept decreases. Is this correct or do you take the slope to be decreasing, because its absolute value decreases?
t = -\frac{2m}{b} \lny + \frac{2m}{b} \lnA.
That's t=0 .
\ln(y) = \ln(A) -\frac{b}{2m}\,t}
Solve this for t .
I was editing my LaTeX and you probably quoted it when it didn't show the natural logs :smile: The original post should have the proper equation.
