Dont know how to word this properly, but a question on volume, flow, and psi.
  • Thread starter Thread starter SwGts
    Flow Psi Volume
Understanding the relationship between volume, pressure (psi), and flow rate (CFM) in a tube is crucial for fluid dynamics. If the volume and psi are known, it is possible to calculate the CFM required to maintain that psi, factoring in pressure drop, fluid density, and viscosity. Maintaining the same volume and psi while increasing CFM is feasible, but it requires adjustments to the system to accommodate the higher flow rate. The flow rate can be approximated using specific equations that consider the pressure drop across the tube or opening. Accurate calculations depend on various factors, including fluid characteristics and flow conditions.
SwGts
I don't know if this is the right section, and I am not entirely sure on how to word this- Hoepfully I can make this clear enough however:
If we know the volume of a setup, for a simple example let's just say a small straight tube. If we know the psi inside this tube, is it possible to calculate the CFM going through the tube to get that psi? Is it possible to Keep the same volume tube, retain the same Psi, and increase the cfm?
Hope I've made this clear enough.
If you know the pressure DROP along a tube (or across an opening) and you know the density and viscosity of the fluid you can get the (approximate) flow rate.
It's slightly different equation depending on the speed etc.
http://en.wikipedia.org/wiki/Orifice_plate
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
