Doppler Effect: Airplane, Sound, & Frequency
A siren on an airplane traveling faster than the speed of sound would still emit sound, but it would only be heard after the plane has passed. As the airplane approaches the speed of sound, the wavefronts compress in front and stretch behind, leading to unique auditory effects. If the plane travels at twice the speed of sound, sounds would arrive in reverse order, creating an effect where spoken words would be unintelligible when heard backwards. The Doppler equations remain valid, predicting negative frequencies and the arrival of later-emitted signals before earlier ones. This concept raises intriguing implications about time and sound, potentially inspiring science fiction narratives.
barryj
This is not homework but rather a concept question.
If there was a siren on the front of an airplane that is traveling greater than the speed of sound, would there still be a sound emitted?
If the airplane was traveling toward me what would be the frequency? Would I heart it?
Where would the Doppler equations break down?
A sound is still emitted yes. For a stationary source the wavefronts are circles (in 2D). As the source approaches the speed of sound the circles stretch out behind the source and bunch up in front. At the speed of sound the waves bunch up at the tip of the airplane while at the back they stretch out further. At greater speeds, all the waves propagate backwards in the airplanes rest frame (but still radially in the observers rest frame).
You could hear the sound of the airplanes approach but not until after it has passed (i.e the plane would beat the sound). If the plane traveled towards you traveling at twice the speed of sound you would hear the song playing exactly backwards.
The Doppler equations don't break down, they predict negative frequencies when the plane travels towards you, so signals emitted later in time, arrive earlier in time.
"you would hear the song playing exactly backwards." This was exactly what I was wondering. If a person was speaking out the front of the plane, the words would come in reversed but then one could not understand a word played out backwards. Interesting concept.
Yeah it's very interesting, I suppose from this example you can understand a little better why traveling faster than the speed of light can be thought of as traveling backwards in time as well.
These effects could be the basis for a good si-fi movie?
I'm not a Star Trek fan but I think this effect is what makes Warp Drive work haha
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
