Doppler effect and relative motion
The discussion centers on a Doppler effect problem involving a whistle traveling south at 1200 Hz while the observer moves north at 18.0 m/s. The correct apparent frequency calculation requires using the proper formula that accounts for both the source and observer's velocities. One participant initially calculated the frequency as 1051 Hz, questioning the answer key's correctness. It was clarified that the equation used was incorrect and that the observer's velocity should be negative when moving away from the source. The correct apparent frequency, as confirmed, is 1044 Hz.
trulyfalse
Hello everyone! I need some help with a Doppler effect/relative motion question.
A whistle with a frequency of 1200 Hz is traveling south at a velocity of 30.0 m/s. You are traveling north away from the whistle at a speed if 18.0 m/s. If the speed of sound is 340 m/s, what is the apparent frequency of the whistle as heard by you? (Answer: 1044 Hz)
f=(v/v+vs)fs
Relative to myself, the train is moving at a speed of 48 m/s south and therefore away from me. Using the aforementioned equation I calculated frequency at 1051 Hz. Is the answer key wrong or am I missing something?
The equation you have used is incorrect for the case when both source and observer are moving. Can you check in your notes or book for the correct one? It will have both speeds in it, vo and vs. You will also need to note that the velocity of the observer vo in the equation you should find will be negative if he's moving away from the source.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
