Doppler effect car horn question
The discussion revolves around a policeman using the Doppler effect to determine the speed of a car honking its horn as it approaches and passes by. The initial frequency heard by the policeman is 494 Hz, while the frequency upon passing is 440 Hz. Calculations reveal that the car's speed is approximately 83 mph, which exceeds the 40 mph work zone limit, justifying the speeding ticket. Participants clarify the use of the correct Doppler effect formula and discuss the conversion between units. Ultimately, the calculations confirm that the motorist was indeed speeding.
yjk91
A policeman with a very good ear and a good understanding of the Doppler effect stands on the shoulder of a freeway assisting a crew in a 40-mph work zone. He notices a car approaching that is honking its horn. As the car gets closer, the policeman hears the sound of the horn as a distinct B4 tone (494 Hz). The instant the car passes by, he hears the sound as a distinct A4 tone (440 Hz). He immediately jumps on his motorcycle, stops the car, and gives the motorist a speeding ticket. Explain his reasoning.
f0 = f (V(sound) / (V(sound) - V(source)))
since the car is moving toward the policemen it is negative
so
494Hz = 440Hz * (343 v/s / (343 - V))
and V is 37.166 m/s...
which is obviously not..
i'm not sure where i went wrong probably doppler effect..
thank you
Well, I haven't really gone through any of the calculations in your problem... but... just off an initial glance I saw you came up with:
V = 37.166 m/s
Which is a decent answer. And you need to prove that this motorist was speeding past the limit of 40 mph... perhaps a conversion? Doing so would put the motorist's speed at ~80mph which is certainly justifiable for the policeman to pull the motorist over. Or maybe I'm misinterpreting what you're looking for here.
i converted to mph from m/s
and i got 83 mph which still is the wrong answer
i think it's the formula
f(police) = v / (v + v(source)) *f(source)
440 = 494 (767 / (767 + v))
v= 94 mph
does this make sense?
Actually, f(source) = 440 Hz & f(observer) = 494 Hz, so you'll get -94 mph.
The correct answer is 83 mph.
Yeah, I didn't look up the Doppler effect formula, but I thought about it for a few minutes and came up with the following for a stationary observer and moving source:
f = f_0\left[\frac{1}{1 + v/c_s}\right]
where cs is the sound speed, v is the source speed relative to the observer, and I use the convention that:
v > 0 if the source moves away from the observer and,
v < 0 if the source moves toward the observer.
It makes sense at least to the extent that f > f0 for v < 0 and vice versa.
Using this formula, with a sound speed of 343.2 m/s (taken from Wikipedia for dry air at 20 C) I get a result of:
v = -83.9 mi/h
24K
