Dot Product, what's wrong with my method?
rocomath
Find the three angles of the triangle with given vectors.
A(1,0)
B(3,6)
C(-1,4)
I found that AB & BC are congruent, so this ends up being an Isosceles triangle and the only angle I need to find is B.
BC=<3+1,6-4>=<4,2>
AB=<3-1,6-0>=<2,6>
\angle B=\cos^{-1}{\frac{20}{\sqrt{20 \cdot 40}}=45^o
So \angle A = \angle C = \frac{180-45}{2}=67.5^o but this isn't correct, so what am I doing wrong?
It's supposed to be a 45, 45, 90 triangle.
What do you mean AB and BC are congruent? That they have the same length? I don't think so. You used that their lengths are sqrt(20) and sqrt(40). AC and BC are the two equal sides.
Angle A is not congruent to angle C; it is angles B and C that are congruent. Check the dot product of vector AC with vector AB. (This is indeed a right isosceles triangle.) Making a picture of the situation is often helpful in keeping straight which vectors you want to look at.
Thanks! I found my mistake in mislabeling my congruent sides :-[
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
