Solving Double Pendulum Motion w/ Hit on Lower Rod
In the discussion about solving double pendulum motion with a hit on the lower rod, the focus is on deriving the equations of motion using Lagrangian mechanics. The upper rod moves with frequency w while the lower rod moves with frequency -w after the impact. The Lagrangian is expressed as L = T - U, incorporating kinetic and potential energy as functions of the angles and their derivatives. The challenge lies in determining the generalized impulse F, which represents the change in generalized momentum, and incorporating the distance d into this formulation. Successfully finding F will lead to a solution for the distance d that satisfies the motion conditions.
JohanL
If you have have double pendulum of two rods where the rods moves with the same frequency w at the equilibrium position and at the eq. position you hit the lower rod at a distance d from the point that connects the rods. The hit results in a motion where the upper rod moves with frequency w and the lower rod with frequency -w. If the rods lengths are l and their masses m what are the the distance d.
I have no problem to find the equations of motion for the ordinary double pendulum. With the hit i think it gets something like
Lagrange equations = F
Where F is different for theta1 and theta2.
If you find these equations you can solve for which d the resulting motion is w for the upper rod and -w for the lower rod, right?
But how do you write F?
Thank you
You need to right down the lagrangian:
L = T - U
Where T is the kinetic energy and U is the potential energy.
In this case, the lagrangian will be a function of four variables:
L(\theta_1 , \theta_2 , \theta_1 ', \theta_2' )
Where primes denote differentiation with respect to time. So, after you have expressed the lagrangian in terms of those four variables, your equations of motion are the Euler-Lagrange equations (one for each position variable, so two total).
Thank you.
But as i tried to say the problem for me is to find the generalized impulse F.
Because Lagrange equations leads to
F = Generalized impulse = change in generalized momentum
If I find F the problem is solved.
and how do i get the distance d into F?
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
