Double Slit Homework: Order Max at 730 and 558 nm
  • Thread starter Thread starter woaini
    Double slit Slit
The discussion focuses on calculating the order of intensity maxima for light wavelengths of 730 nm and 558 nm in a double slit experiment. For the 730 nm light, the calculated order maximum near 0.205 m from the central maximum is approximately 4. The corresponding order maximum for the 558 nm light, which is closest to the identified order of 4, is also determined to be around 5. Participants clarify the use of the equations and constants involved, emphasizing the importance of correctly interpreting the relationship between the two wavelengths. The conversation highlights the need for precision in calculations and understanding the underlying principles of interference patterns.
woaini
A double slit apparatus is illuminated 730 and 558 nm wavelengths. They form a two-colored interference pattern on a measuring screen located at a distance of 2.28 m from the slits. The slit separation is 42 wavelengths of 730 nm light.
(a) What order (m) intensity maximum for λ = 730 nm light occurs near a distance of y = 0.205 m away from the central zeroth order?
(b) What order maximum for 558 nm light lies closest to this order?
λ1=730
λ2=558
L=2.28
m=?
d=42*730
mλ=dsinθ
tanθ=y/L
tanθ=.205/2.28 θ=5.14
a) m=(dsinθ)/λ = 3.76 (4?)
a) m=(dsinθ)/λ = 4.92 (5?)
So did I get the slit separation right? Are my orders suppose to be decimal numbers and do I round up or down?
Your working for a) looks right, but it bothers me that it's not closer to a whole number. Doesn't strike me as particularly 'near'. As a check, I adjusted for the fact that d/D is really tan(theta), but it made hardly difference.
For b), although it's worded a little oddly, I think it's asking which order of 558nm max is nearest the 730nm max you just identified. Note that this not quite the same as asking which order of 558nm max is nearest 0.205m from the central axis. (But it still gives 5 as the answer.)
So if it's near the 4th order, I would do this:
arcsin((4*750)/(42*730)) = 5.61
L*tan(5.61)=0.224m
y2=0.224m
I'm lost here. :(
You mean 4*730, right? so it reduces to 4/42. But it's much simpler than this.
Write out the mλ=dsinθ equation for the two different wavelengths. Which variables are the same between the two equations?
The dsin remain constant right?
Yes, d and θ are constant. So what equation can you write for the rest?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
