How Do Different Wavelengths Overlap in Double-Slit Interference?
In a double-slit interference experiment with slit separation of 8.40 x 10^-6 m and distances of 2.80 m to the screen, two light wavelengths (450 nm and 600 nm) are used. The discussion centers on determining which order bright fringes from both wavelengths overlap on the screen when shone simultaneously. Participants suggest setting the equations for bright and dark fringes equal to find common fringe orders, while also questioning the relevance of the m + 0.5 term. It is emphasized that a difference in fringe order of one is necessary for overlap, and exploring cases with greater differences may yield additional solutions. The conversation highlights the importance of careful consideration of wavelength and fringe order in solving the problem.
LegendLen
In a double-slit interference experiment the slit separation is 8.40 x 10-6 m and the slits are 2.80 m from the screen. Each slit has a width of 1.20 x 10-6 m.
2 lights of wavelength 450nm and 600nm are shone on the same slits.
If both of the above light sources are shined on the slits at the same time, which order bright fringes from the two light sources would occur at the same locations on the screen? Include the orders of all possible fringes that would overlap.
dsin
= m
dsin
= (m +0.5)
Ok so this is part of a multi-part assignment. Using the equations above I've determined "how far (in meters) from the center of the interference pattern on the screen will the third order (m = 3)" be for the bright (450) and dark (600) fringes separately. The next part of the question asks about shining them at the same time and about bright fringe orders.
My guess was to set both equations equal to each other without m and having both dsin
cancel out leaving m
= (m + 0.5)
and calculating for the order, but I realize this will only give me potentially one answer so I feel like my methods are incorrect.
Could someone give me some guidance about how to approach this question?
Why are you using the equation with ##m+0.5## in it? Does it even apply to this problem? Don't you also need to keep track of the wavelengths? You seem to be using ##\lambda## to represent both at the same time.
I agree with Vela, where does this 0.5 come from?
The question is: what is the value of n for which a fringe due to (λ1) will coincide with that a fringe of λ2). The first occurrence will occur when one of the wavelength has created an extra fringe compared to the other... (So a difference in fringe order of 1...). Rewrite your equation taking this into account, and find the value of n that will satisfy such condition.
"I realize this will only give me potentially one answer...". You can also explore the case where the difference of order is more than 1, and see if such solution is possible by checking that sin([PLAIN]http://theory.uwinnipeg.ca/physics/light/img32.gif) remains <1
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
