Doubt in equilibrium of rigid body
The discussion centers on the equilibrium of rigid bodies, specifically the role of reaction forces from different support types. A roller or rocker restricts movement in one direction, while a smooth pin or hinge restricts movement in all directions, resulting in two force components. The example of a ladder leaning against a wall illustrates how the rough floor prevents both sliding and downward motion, highlighting the need to analyze forces as components for easier calculations. It is noted that the total reaction force does not always act perpendicular to the surface, complicating the analysis. Understanding these concepts is crucial for accurately determining the forces in equilibrium scenarios.
ehabmozart
Hello there! I am currently studying the equilibrium of rigid body and encountering a doubt. Now, in their explanation of reaction forces by a roller or a rocker or a smooth surface, they generalize it as in the preceding examples prevent the translation of a beam for example in ONE direction only whereas a smooth pin or hinge or a rough surface prevent translation of the beam in ANY direction, thus there are two components of the force. How is it so? I can understand that a roller cannot prevent the beam from moving upwards for instance but at least in can prevent the beam from penetrating the surface downwards in any direction.
If the body would accelerate in some direction but for an obstruction, then we deduce the obstruction supplies an equal and opposite force to oppose the acceleration.
Since forces can point every which way, it is often handy to represent them as components, usually at right angles to each other, which add up to the actual force. This is to make the maths easier.
A ladder leans against a wall - the feet of the ladder are on a rough floor.
It is easy to see that the floor prevents sliding away from the wall and also prevents the ladder falling directly downwards - so these are two components of the overall force provided from the floor. The total force from the floor is the sum of these two. It is a lot harder to find the total force in one go.
The total force does not act normal to the floor - so the total is sometimes called a reaction force.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
