Solving 82C55 Doubt: Usage & Examples
  • Thread starter Thread starter i.mehrzad
    Doubt
The 82C55 is a programmable peripheral interface commonly used for interfacing with devices like keyboards, where it manages input and output operations. It is not necessary for simpler devices such as LCDs, which can often be driven directly by microcontrollers. Users seek application notes and examples to better understand its functionality and appropriate use cases. The discussion emphasizes the need for clarity on when to implement the 82C55 in various applications. Understanding its role enhances effective interfacing in microcontroller projects.
i.mehrzad
I have a basic doubt about the usage pf 82C55.
Wanted to know when exactly it is used. Eg: For a keyboard you have to use a 82C55 but for a LCD it is not necessary. So when exactly do we use it??
Can you give us some links to application notes for that PPI part? What are your thoughts on when and why it is used?
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
