Draw a diagram to interpret this equation geometrially as an equality
  • Thread starter Thread starter DivGradCurl
    Diagram
The discussion revolves around proving three integral equations involving continuous functions and interpreting them geometrically. The first equation shows that the integral of a function evaluated at negative inputs is equal to the integral over a symmetric interval, which can be visualized as symmetric areas about the y-axis. The second equation illustrates that translating the input of a function results in an equivalent area under the curve, which can be represented by a shifted diagram. The third equation demonstrates the equality of two integrals involving powers of x and (1-x), which can also be visualized through substitution. The participants express confidence in their algebraic manipulations but seek guidance on creating the corresponding diagrams for the first two problems.
DivGradCurl
I need some help with the following problems. Any help is highly appreciated.
1. If f is continuous on \mathbb{R}, prove that
\int _a ^b f(-x) \: dx = \int _{-b} ^{-a} f(x) \: dx
For the case where f(x) \geq 0 and 0 < a < b, draw a diagram to interpret this equation geometrially as an equality of areas.
2. If f is continuous on \mathbb{R}, prove that
\int _a ^b f(x + c) \: dx = \int _{a+c} ^{b+c} f(x) \: dx
For the case where f(x) \geq 0, draw a diagram to interpret this equation geometrially as an equality of areas.
3. If a and b are positive numbers, show that
\int _0 ^1 x^a (1 - x) ^b \: dx = \int _0 ^1 x^b (1 - x) ^a \: dx
Here is what I've got so far:
1. Consider the left-hand side
and apply the substitution rule:
u=-x \Rightarrow \frac{du}{dx} = -1 \Rightarrow dx = - du
u(b)=-b
u(a)=-a
\int _a ^b f(-x) \: dx = -\int _{-a} ^{-b} f(u) \: du = \int _{-b} ^{-a} f(u) \: du = \int _{-b} ^{-a} f(x) \: dx
2. Consider the left-hand side
u=x+c \Rightarrow \frac{du}{dx} = 1 \Rightarrow dx = du
u(b)=b+c
u(a)=a+c
\int _a ^b f(x + c) \: dx = \int _{a+c} ^{b+c} f(u) \: du = \int _{a+c} ^{b+c} f(x) \: dx
3. Consider the left-hand side
u=1-x \Rightarrow \frac{du}{dx} = -1 \Rightarrow dx = -du
u(1)=0
u(0)=1
\int _0 ^1 x^a (1 - x) ^b \: dx = \int _1 ^0 u^b (1 - u) ^a \: du = \int _0 ^1 x^b (1 - x) ^a \: dx
This looks fine to me.
Where do you need help?
Oh, good! Thanks for checking it out.
Other than that, I need to take care of the diagrams (problems 1 & 2). I'm not so sure how to handle those. It seems that the areas in #1 are symmetric with respect to the y-axis.
You're right about diagram 1.
For diagram 2, remember that f(x+c) represents a translation.
I've got it. Thanks!
