Drums rolling downhill scenario
  • Context: Undergrad
  • Thread starter Thread starter Skhandelwal
    Rolling
The discussion revolves around a scenario involving drums rolling downhill, focusing on their different physical characteristics such as surface area and center of mass. Participants explore the implications of these characteristics on the drums' motion, examining principles of mechanics and inertia.
  • One participant notes that all drums weigh the same but differ in surface area and center of mass, questioning which will reach the ground first and expressing uncertainty about their understanding of mechanics.
  • Another participant explains that the force acting on the drums is the component of gravity parallel to the inclined plane, suggesting that the resistance to this force is due to the drums' inertia, which includes both linear and angular components.
  • One participant claims that the drum with the larger surface area will reach the bottom first, despite facing more friction, and questions whether the center of mass affects speed compared to a drum with mass at a corner.
  • A different participant asserts that the fastest drum is the one with mass at its center, arguing that surface area is irrelevant unless considering air friction, and states that a central mass results in minimal angular inertia.
Participants express differing views on which drum will reach the ground first, with no consensus reached on the influence of surface area and center of mass on the drums' motion.
Participants do not clarify the assumptions regarding friction types or the specific conditions of the incline, leaving these aspects unresolved.
Skhandelwal
All the drums weigh the same...one has greater surface area , one has center of mass in the middle...and one has center of mass at an end.
Which will get to the ground first?
When I think I am starting to understanding mechanics, I spot questions like these... If I am having problem w/ this...what principle am I weak on?
The force is the component of gravity that is parallel to the angle of the inclined plane (cos(angle)). The resistance to this force is the inertia of the drums, which is a combination of the linear and angular inertias. Since the drums have the same mass, the linear inertia is the same for the drums, so the only difference is the angular inertia. See if you can figure it out from here.
The one w/ the bigger area will get at the bottom first...even though, it has to face more friction...the surface area makes up for it. Btw, is the center of mass faster or the one which has the mass at a corner?
Also, another similar question, if there is a drum, and then there is another drum but there is one difference. Assume the drum is a pizza made up of 16 slices. Well, every alternative slice has been taken out. Which one will get to the ground first?
The fastest drum is the one with it's mass at it's center. The surface area doesn't mattter unless you're including friction from the air. If the mass is at the center, then there's virtually no angular inertia.
  • · Replies 59 ·
  • · Replies 19 ·
  • · Replies 37 ·
  • · Replies 31 ·
  • · Replies 35 ·
  • · Replies 116 ·
13K
