Dual axial flux PMG wind turbine
The discussion centers on building a small vertical Savonius wind turbine, focusing on maximizing power at low wind speeds using specific materials like 14awg wire and ceramic magnets. There is a noted relationship between wire gauge, number of turns, and magnet strength, but the Savonius rotor is criticized for its inefficiency compared to other designs. The issue of the generator stalling when measuring current is explained as a result of the energy draw during testing. The choice of a Savonius rotor is justified by its portability and safety for off-grid applications, despite its limitations. Overall, the conversation highlights the trade-offs between design efficiency and practical use cases for small wind turbines.
gratefuldan
I am making a small vertical savonius type wind turbine and would like some general rule guidelines. I am using 14awg magnetic wire--70 turns (2"oval) and ceramic block 1" x 2" x.375" magnets. I am hoping to get the most power possible at lower wind speeds. Is there a rule that states a relationship between wire gauge, turns, magnet strength ie thicker wire,more turns stronger magnets=max power.Also when testing my voltage it spins freely-then test amps and it comes to a screeching halt. is this a problem-if so, how do I fix it?thanks
When you measure voltage you are using a high impedance voltmeter that takes almost no energy from the generator. When you measure current you take real energy from the generator and so magnetically brake the generator.
Ask yourself; why do we not see more Savonius rotors being built and used productively
A Savonius rotor is the most inefficient rotor available. Unfortunately beginners get fixated on the SR and so can never advance to designs with 10 times the efficiency. The cost of the structural tower needed to handle high winds for a SR is way more than a standard windmill tower where an offset tail can turn the head sideways to reduce damage in strong winds.
As the devil's advocate I will point out that: An axial flux generator will be less efficient than a traditional design because the magnetic flux path and the length of copper required for the same performance will be greater. Couple that to an inefficient SR, that will stall unless it is duplicated, and you have the engineering equivalent of double jeopardy.
Baluncore,thanks for your reply.The reason for the Savonius type rotor is for ease of transportation, size, safety and low wind start up. Basically I am trying to fill a portable power niche for people to charge a battery either in an emergency or for leisure--when off grid.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
