Dual axial flux PMG wind turbine
The discussion focuses on the design and efficiency challenges of a small vertical Savonius wind turbine utilizing 14 AWG magnetic wire with 70 turns and ceramic block magnets measuring 1" x 2" x 0.375". Key issues include the relationship between wire gauge, turns, and magnet strength, as well as the generator's performance under load, where measuring current causes the turbine to stall. The Savonius rotor is identified as inefficient compared to other designs, leading to recommendations for exploring more efficient alternatives for portable power applications.
  • Understanding of Savonius rotor design principles
  • Familiarity with axial flux generator mechanics
  • Knowledge of electrical measurements, including voltage and current
  • Basic concepts of wind turbine efficiency and performance metrics
  • Research advanced wind turbine designs, focusing on efficiency improvements over Savonius rotors
  • Learn about axial flux generator optimization techniques
  • Explore the impact of wire gauge and turns on generator performance
  • Investigate portable power solutions for off-grid applications
Engineers, hobbyists, and anyone interested in wind energy solutions, particularly those focused on portable power generation and optimizing turbine efficiency.
gratefuldan
I am making a small vertical savonius type wind turbine and would like some general rule guidelines. I am using 14awg magnetic wire--70 turns (2"oval) and ceramic block 1" x 2" x.375" magnets. I am hoping to get the most power possible at lower wind speeds. Is there a rule that states a relationship between wire gauge, turns, magnet strength ie thicker wire,more turns stronger magnets=max power.Also when testing my voltage it spins freely-then test amps and it comes to a screeching halt. is this a problem-if so, how do I fix it?thanks
When you measure voltage you are using a high impedance voltmeter that takes almost no energy from the generator. When you measure current you take real energy from the generator and so magnetically brake the generator.
Ask yourself; why do we not see more Savonius rotors being built and used productively
A Savonius rotor is the most inefficient rotor available. Unfortunately beginners get fixated on the SR and so can never advance to designs with 10 times the efficiency. The cost of the structural tower needed to handle high winds for a SR is way more than a standard windmill tower where an offset tail can turn the head sideways to reduce damage in strong winds.
As the devil's advocate I will point out that: An axial flux generator will be less efficient than a traditional design because the magnetic flux path and the length of copper required for the same performance will be greater. Couple that to an inefficient SR, that will stall unless it is duplicated, and you have the engineering equivalent of double jeopardy.
Baluncore,thanks for your reply.The reason for the Savonius type rotor is for ease of transportation, size, safety and low wind start up. Basically I am trying to fill a portable power niche for people to charge a battery either in an emergency or for leisure--when off grid.
  • · Replies 35 ·
11K
