How to Convert kg Oil Equivalent to 1000 TOE Units: A Simple Guide
  • Thread starter Thread starter physicsss
To convert kg oil equivalent to 1000 TOE units, first recognize that 1 ton equals 1000 kg. Given 1698 kg of oil equivalent, you need to convert it to tons by dividing by 1000, resulting in 1.698 tons. Since 1 ton of oil equivalent equals 1 TOE, you then express this in units of 1000 TOE by dividing by 1000 again. Therefore, 1.698 tons of oil equivalent equals 0.001698 TOE. The conversion process involves dividing the initial kg amount by 1,000 twice to achieve the desired units.
physicsss
I'm sorry for posting this, but I'm really confused by the following.
The problem states to use units of 1000 TOE("tons of oil equivelent, where 1 ton = 1000 kg) So if I'm given 1698 kg oil equivalent, I need to divide by 1000 twice to get to the units of 1000 TOE?
Thanks.
1 ton = 1000kg
1 ton of oil equivalent = 1000kg of oil equivalent
I understand that, but they want it in units of 1000 TOE, so I divide TOE by 1000, right?
Yes, indeed.
