Dummy proofing roll feed direction
  • Thread starter Thread starter Argyles
    Direction Roll
Operators at laminating machines are incorrectly loading products in the wrong direction, causing operational issues. A request for a simple solution to prevent this mistake has been made, with a preference for mechanical methods over optical sensors. Suggestions include using clear directional arrows to indicate the correct loading orientation. The goal is to create a "dummy resistant" system rather than a foolproof one. Implementing visual cues could effectively reduce errors in product loading direction.
Argyles
So here's the the problem. We have a number of laminating machines at my work and the machine operators occasionally put the product onto the unwind chuck in the wrong direction (i.e. clockwise rather then counter clockwise). We need a SIMPLE way to insure that this does not happen. I'm aware of the use of optical sensors to accomplish this however it would be nice if there was a simpler more mechanical solution to the problem. Any thoughts...?
I'm not sure about "dummy proof," but you might be able to make it "dummy resistant" with a couple of arrows showing which direction the material should face...
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
