Dynamics help: Spring force and dynamic motion
The discussion focuses on calculating the velocity of a block connected to a spring as a sphere falls. The sphere has a mass of 20 kg and a spring stiffness of 500 N/m, with the block weighing 10 kg. The user derived equations for the forces acting on both the sphere and the block, considering factors like spring force and friction. They arrived at a velocity of 1.76 m/s for the block after applying the work-energy principle. However, there are concerns about the accuracy of the equations and the need for clarification on the forces involved.
medynamics
The 20-kg sphere, attached to a spring of stiffness 500 N/m
is released from an un-stretched position of the spring, as
shown in the figure. Determine the velocity of the
block “A” of mass 10 kg, at the instant the ball has fallen
25 cm. A roller mechanism keeps the spring in a vertical
position. Ignore the size of the ball and the mass of the
spring and roller mechanism. The coefficient of kinetic
friction between the block “A” and the ground is 0.25
Here is an image of the problem:
http://s1306.photobucket.com/user/wellthisisdumb/media/1_zps80a2c31a.png.html
All angles in the triangle are 60°.
I started by making free-body-diagrams for the ball and the block, then I made separate diagrams for the Normal force between the two objects.
Here are the diagrams:
http://s1306.photobucket.com/user/wellthisisdumb/media/2_zpsf6514a00.png.html
I know that as the ball falls, the spring force increases, so the effect of the ball on the block's movement will decrease with distance, so I know I need an equation for motion of the block in terms of x(the displacement of the ball).
Wb = Weight of Ball(B)
Wa = weight of block A
Fs = spring force
Ff = frictional force
Na = Normal force of A
Nb = Normal force of B
Wb = mg = 20(9.8) = 196N
Wa = mg = 10(9.8) = 98N
Fs = 500(.25) = 125 N
Nb = Wb - Fs
= 196 - 500x
Na = Wby + Wa
= Nbsin60 + 98
= (196 - 500x)sin60 +98
= 267.7 - 433x
Wbx = Nbcos30
= (196 - 500x)cos30
= 169.7 - 433x
Ff = μNa
= .25(267.7 - 433x)
= 66.9 - 108x
ƩFx = Wbx - Ff = MaAx
(169.7 -433x) - (66.9 - 108x) = 10Ax
102.8 - 325x = 10Ax
10.28 - 32.5x = Ax
I have my equation for the acceleration of the block in terms of the motion of the ball, so next I used ads = vdv to solve for velocity
ads = vdv
∫ads = ∫vdv (ads from 0 to .25, vdv from 0 to V)
∫(10.28 - 32.5x)dx = 1/2(v^2)
10.28x - 16.25x^2 = 1/2(v^2)
10.28(.25) - 16.25(.25)^2 = 1/2(v^2)
1.55 = 1/2(v^2)
3.1 = v^2
1.76 m/s = v
So I got v = 1.76 m/s as my answer. My professor said to use ads = vdv to solve the problem, and this is the only way that I could get to even using ads = vdv. I feel like I've done it correctly, but we've never done a problem even similar to this in class, so I'm just kind of lost.
If someone could verify that I got the right answer that would be great, and if it's wrong I'd really appreciate a step-by-step solution. Thank you!
I apologize in advance for how long this post is. I'm a mediocre formatter.
In your diagrams (top right) you have a Wb which I assume should be Nb. Anyway, Na = Nb, right?
In your equations you have Nb = Wb - Fs. Do you mean Nby = Wb - Fs? Even then, you're ignoring that there has to be a resultant vertical force on the ball to account for its acceleration. I haven't checked the rest of your work.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
