How do different masses affect the dynamics of falling objects?
  • Thread starter Thread starter osmundsaddler
    Dynamics Falling
osmundsaddler
Please see image- Dead problem
I want to know, first off, if the two masses hit the ground at the same time (according to my solution, they do, but my friends claim otherwise), secondly, if not how to correct my solution to find the correct times and difference and finally, if (see image 2- second order equality?) is correct.
I end up with an identical time for both masses, to first order k/m. However I think there may be more to it than that... does the lamda*mass term change things for the heavier mass? Or is my working correct? If you can give any other advice or feedback, please do so. I have been stumped on this problem for days now and need to hand it in.
Please see the remaining file- different mass time solution. I have typed up my solution via Mathtype then put it in a Word document because I am unsure how else to express it on a message board? If you want pictures perhaps I can post again and do it that way, or whatever you suggest. Again please help me I am nearly finished and my attempt at posing this on another student help board has proved fruitless... *Edit- I wouldn't have posted this question here if I hadn't noticed that you guys seem a lot more helpful than those on the other forum, so I really do hope I finish this thing finally with your help. :)
  • different mass time solution.doc
Just type it up in the post. For the formulas you can use LaTeX; click on the little sigma above the text box to get a LaTeX reference. Your Word document is practically illegible on my computer. (Generally speaking, word processing documents are a lousy format for calculations)
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
