Dynamics: solve both trajectories
The discussion revolves around solving a dynamics problem involving projectile motion, specifically finding the angles (thetas) required to hit a target at coordinates (5000m, 1500m) with an initial velocity of 400 m/s. The user outlines their approach using kinematic equations for both x and y directions, noting the challenge of eliminating time (t) from the equations. They inquire about applying the quadratic formula to the resulting equation for y(Θ) and express confusion regarding the presence of secant and tangent functions in the equation. A participant confirms that it is possible to solve the quadratic equation for Θ and emphasizes the importance of understanding trigonometric identities to simplify the problem. The conversation concludes with the user feeling more confident after realizing they can substitute and solve despite the complexity.
600burger
Hey all,
Having trouble solving this one. Class is dynamics. 2D, constant accel.
Shooting a cannon at a point above the initial. Inital velocity is 400m/s
Cannon is at point A (origin) and we're shooting at point B @ (5000m, 1500m)
I'm asked to find the two thetas that satisfy.
So i got this so far, basicly the givens.
In the x:
ax = 0
vx = v0*cos(Θ)
x = v0*cos(Θ)*t
In the y:
ay = -g
vy = v0*sin(Θ)-gt
y = v0*sin(Θ)*t-(1/2)gt2
I tried to eliminate t is the y position equation by
1) solving x for t
2) subing into y(Θ,t) for t to get y(Θ)
3) solving for Θ
I can't get through solving for Θ. Can I use the quadradic equation on y(Θ) to solve for Θ? How do i do that?
600burger said:
... Can I use the quadradic equation on y(Θ) to solve for Θ? How do i do that?
Yes, you should be able to solve the quadratic equation for \Theta, after plugging in the values of displacement 5000 m and 1500 m.
Thats what my prof was saying, but I am not sure how that's done? cause it some up to like
-a*sec(Θ)^2 +b*tan(Θ) - c = 0
so does it matter that Θ is in sec^2 for the a and tan for b?
**In the voice of reason**
Learn your trig identities backwards and forwards!
*echo 7th grad algebra teachers voice
**End voice**
sec(Θ)^2 = 1 + tan(Θ)^2
Sub and solve. Still an ugly problem, but I'm gald I figured it out.:-p
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
