Discover the Charge on Two Suspended Charged Balls with E and M Help!
  • Thread starter Thread starter angiecakes
The discussion revolves around calculating the charge on two suspended charged balls, with one participant arriving at a charge of 1.33x10^-6. The problem involves two balls with a mass of 30g each, suspended at a 60-degree angle from vertical. Participants emphasize the importance of using trigonometry to determine the distance between the balls and correctly applying the formula for electrical force. There is a suggestion that the initial calculations may have incorrectly equated forces acting in different directions. Clarification on the methodology used to reach the answer is requested for further verification.
angiecakes
E and M help!
I got 1.33x10^-6 for this question, can someone please verify/check it?
"two charged balls are suspended on light 10cm strings. Each has a mass of 30g. In equilibrium, the total angle between the strings is 60 degrees. Assuming the balls are equally charged, what is the charge on each ball?"
Thanksss!
I'm assuming the balls would be right next to each other if hanging straight down?
Did you
A)Use trigonometry to figure out the distance between the balls at equilibrium?
B)Use F=c*q^2/r^2 to figure out the force on the balls in terms of q?
C)Use trig to figure out the force from gravity acting in the "swinging" direction on the balls?
D)Use trig to figure out the electrical force(in terms of q still)acting against the "swinging" direction?
E)Set those two equal and solve for q?
What you probably did wrong, if you did something wrong(I didn't check the math)is do F=c*q^2/r^2 just like that, which is the force going in a straight line between the two, and set that equal to the gravitational force that's NOT going in a straight line between the two, and it's not going to work
I think it would help us if you posted exactly what you did to get the answer you've stated angiecakes.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
