What are the equations for trajectory in an E-field?
  • Thread starter Thread starter jasper10
    Trajectory
The discussion focuses on the trajectory of an electron in a uniform electric field, particularly when it enters at an angle of 30 degrees above the field direction. Key concepts include the use of trigonometric functions, specifically tan, sin, and cos, to resolve the initial velocity into components. The equations provided for calculating the trajectory include v = ucos(ß) + at, v^2 = (ucos(ß))^2 + 2as, and s = (ucos(ß) x t) + 0.5at^2. Understanding these equations is crucial for solving related problems in the physics exam. Mastery of these concepts will aid in accurately predicting the electron's path in an electric field.
jasper10
Hello, I have a physics exam on friday. My teacher said one of the questions would be on the TRAJECTORY (of an electron) IN AN E-FIELD. he told us to remember than tanß = sinß / cosß
we haven't used tan, sin or cos during class work. I was hoping someone could give me a clue to what he means.
Thanks
he means that you will need to use tan(beta)
yes i know he will give us some form of equation or something to do with tanß
but how is this related to the trajectory in an e field?
say a uniform electric field points in the x direction. but the electron enters the E field at a certain speed 30 degrees above the direction of the E field, then you are going to have initial components of velocities that involve sine and cosine
So would the equations be:
v = ucosß + at
v^2 = (ucosß)^2 + 2as
s = (ucosß x t ) + .5at^2
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
