E&M Electric Fields (Harmonic Motion?)
The discussion revolves around a physics problem involving two fixed charged particles and a third movable particle, exploring its motion along the perpendicular bisector. Participants suggest using Coulomb's law to calculate the net forces acting on the movable charge and emphasize the importance of expressing these forces in a form that resembles Hooke's law for simple harmonic motion. There is a consensus that determining the period of motion can be approached by analogy to spring motion. Additionally, some contributors recommend considering electric potential energy as an alternative method for solving the problem. The conversation highlights the connection between electric forces and harmonic motion principles.
physicsnewblol
This problem comes out of "Physics (for scientists and engineers w/ modern physics) Volume 2 7th Edition" by Serway/Jewett
Review Problem Two identical particles, each having charge +q, are fixed in space and separated by a distance d. A third particle with charge -Q is free to move and lies initially at rest on the perpendicular bisector of the two fixed charges a distance x from the midpoint between the two fixed charges.
A. Show that if x is small compared with d, the motion of -Q is simple harmonic along the perpendicular bisector. Determine the period of that motion.
Regarding harmonic motion, I don't even know where to begin. This problem most likely has something to do with Coulomb's law but I don't see how that helps.
Edit: I can find the net forces by adding each of the respective components together, but I have no clue what to do then.
Anyone have ideas?
-Physicsnewblol
This sounds like a good plan. I would write out the net force acting on the third particle as a function of position (x).
Alternatively, one could try to compute the electric potential energy of the system... as a function of position (x).
found a little blurb in my book: "If the equation of the force is in the form of the f = -kx (I forget the name, it has to do with springs) then the motion is simple harmonic"
Yes, that hooks in directly with Hootenanny's hint.
If you know how to determine the period of a spring, then you could finish the problem... by analogy.
(By the way, my suggestion uses energy instead of force, which might be easier to work with. But, at this stage, it might be better to follow the suggestion in your blurb.)
:smile:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
