Earth Resistance: What Is It & Standard Value w/Refs
  • Thread starter Thread starter Arifur
    Earth Resistance
Earth resistance refers to the resistance encountered by electrical currents flowing through the ground, often measured in ohms. The standard value for ground resistance is typically recommended to be less than 5Ω for telecommunications and electronics, while a value under 25Ω is acceptable for other applications. Soil resistivity, which varies based on moisture and temperature, generally ranges from 10 to 1000 Ω-m. Resources for further understanding include technical documents and Wikipedia entries on soil resistivity. Accurate measurements of earth resistance are crucial for ensuring safety and performance in electrical systems.
Arifur
What is Earth resistance? What is the standard value of Earth resistance? Please help me with reference.
Your co operation will be highly appriciated.
Do you mean "ground resistance" (<5Ω recommended for telecommunications & electronics, <25Ω otherwise)? or "soil resistivity" (varies with moisture and temperature typically from 10 to 1000 Ω-m)? or something else?
For ground resistance, see https://support.fluke.com/find-sales/Download/Asset/2633834_6115_ENG_A_W.PDF.
For soil resistance, see https://en.wikipedia.org/wiki/Soil_resistivity
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
